No added features on Stock p28 basemap "Crome"
I was messing around on Crome and I noticed that the p28 basemap does not support the 2 step launch control. Is this normal? Why is it only the p28 base that does this? Im just curious, never started a base on a p28 before.
FYI don't tell me Crome is useless. LOL
I tried it on the p30 base but once doing that it did not allow me to change the RPM scolars on the p30 basemap to match the p28.
www.artietuned.com/p30-p28tables.bin
p30 base code with p28 ignition and fuel tables with extra features added.
You probably dont have all the correct plugins installed, gimme ur email, i'll send you my full folder. where everything is installed and properly labeled.
This is what I do
Click Next
It doesnt say anything on the added features like it does on other basemaps
End results. No added features
Sorry shitty phone pictures
I have no idea on that. I can add it to any other basemap besides the p28. But yeah here's my email. moua6388@Hotmail.com. Thanks Derek
Yes I understand that. But I dont get why I cant change my RPM scolars on the p30 basemap to match the p28. Thats where I am confused.
Same concept as eliminating the IAB's from a p72 basemap but copying the fuel and ign maps to the p30 base. Changing the RPM scolars to match.
Use a p30.. dont use a p28..there's no need to change the rpm scaling its basically the same.
is that the folder i sent you??
No I havent check my email yet. Ill check it right now.
Back then when I read Crome's basic guide. It stated to change the rpm scaling so I was just doing what I read. This was a link from Xenocron I believe
also there is a much easier way....open the p28 bin...click on file top left corner go down to export tables and save the tables....open p30 bin click on file go to import tables and it will change everything for you.
ONEhb2NR
Jul 24, 2005 11:03 PM
