intake manifold
Yes a manifold is not something that one can put together and expect good performance, it needs lots of R&D testing to come up with a manifold that can perform good "for a specific engine". Spend the extra money on a well designed manifold suited for ur engine and you will be happy!!
My friend designed a "box type plenum" manifold. It litterally looked like a damn box with four runners. It was terrible to tune and idled like poop. I am not dis-couraging you, I am just saying you can't just get a bunch of sheet metal and make a random shape.
thanks for the replys... im looking around for a good match up for my setup....
i was thinking about the gato tuning intake manifold... then i saw ipgparts.com's allmotor eg wit it and im leaning over to that manifold more... wat do you guys think of that product??
eagle rods
cp 13.5.1 high comp pistons
gs-r head (ported and polished)
supertech valve train (oversized valves)
looking around for roller rockers
with some killer cams
intake mani?
b16 tranny (obx lsd)
4.4 final drive
competion clutch stage.5 clutch
that rite there is what i have....
If you are looking at GATO you should also look at Magnus and BMC.
I have come across a few aftermarket manifolds modified.
A Performer X with shortened runners. A Victor X with and enlarger plenum. Skunk2 Pro, ITR and Victor X CnC'd.
Very soon my custom GSR manifold, IAB still active and over 300cfm. Out flows a Px and Skunk2 Pro.
And I did a ton of research on manifolds over the past year. I am planning on doing a write-up of my findings for our B-series engines. To much incorrect or wrong information out there.
Ooo I can't wait to see that.
My focus was on the design deficiencies in the GSR manifold as they impacted performance. Plenum size (needed more), runner length (to long, slowing down the air speed), and the IAB (cross section at the butterflies and air flow into the runners).
You need to remember that manifold was originally designed in the early 90’s, as was the P30 and ITR manifolds. What kind of computing power did we have back then? Same as our smart phones today, at best. What about the programs that where available to do complex fluid dynamics? They took hours to run and were not very accurate.
More to come as I get my thoughts together, I have pictures that will also be included.
btw, cant wait to see the results from the gsr mani. if erick was running crazy times with it years back, then there's obviously something to it that can make it work
that magnus intake looks crazy.... it out powers the jg intake by 11hp and 9trq...
yes technology has gotten better but you cant say that itr mani is worthless or outdated. the itr mani was made so long ago, and even with new off the shelf (not custom) manifolds coming out, the itr mani still does the job, and even a better job when modified.
I think the Magnus was tested against a CnC'd Victor X. Even more impressive.
BluePrintmfg.com
78
Oct 6, 2008 10:49 PM
