Throttle Body/Intake Manifold Combo Question...
Old Dec 5, 2010 | 08:39 AM
ExtraBlackRex's Avatar
Default Throttle Body/Intake Manifold Combo Question...
Ok so i was throwing around a few boxes, i'm nearly at the end of switching garages over and Low and behold I come across a Skunk2 Pro Series Intake Manifold for the LS I had lying around, and it's still in pretty good shape...
I was wondering, if the H22 Throttle Body was compatible with this manifold??? I know the H22 Throttle body's are BIGGER then both the B and D series TB's diameter wise but does it fit???
I figure this would be a cheap (Free) add on that will definitely give me some usable power...
Old Dec 5, 2010 | 08:47 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: Throttle Body/Intake Manifold Combo Question...
H22 is only a 60mm, same as almost any b series, who told you it was bigger?
Old Dec 5, 2010 | 09:34 AM
Always assumed that the H22's were bigger, then again i've never had a stock diameter TB on any H i've owned so the misconception must have came there, guess I might as well stick with the stock TB or purchase a larger after market one.,.
youhan23
Feb 23, 2012 12:48 PM
McLude2nR
Nov 22, 2006 08:13 AM
germanEE8
Feb 25, 2004 01:56 AM
ebp 99 si
Feb 3, 2004 12:47 PM
civicmatt
11
Jul 9, 2003 06:40 PM
