Need Some Guidance For My B18c1 Build
Been putting together a motor for a while and just wanted to see if im going down the road of success or probs. Just wanted to know what to expect
heres what i have so far and plan on getting..
b18c1 head
s2p2 cams
s2p cam gears (need to buy)
s2p intake manifold or edelbrock perfX (undecided)
s2p springs
s2p retainers
omni power 68mm TB
supertech flat face valves
supertech valve guides
oem valve seals
310cc injectors (haven't bought yet)
(undecided on what header to go with also)
b18c1 block
oem jdm itr pistons (oversized) w/new rings
shotpeened gsr rods
ARP headstuds *new*
oem oil pump *new*
oem water pump *new*
taking the block to the machine shop for measurements for the rod bearings.
ACL bearings i had were too thick.
b18c1 head
s2p2 cams
s2p springs
s2p retainers
omni power 68mm TB
oem valve seals
b18c1 block
shotpeened gsr rods
ARP headstuds *new*
oem oil pump *new*
expect this http://www.youtube.com/watch?v=-k3pU...eature=related lol
Looks like a solid setup. I posted a thread on here called "Best B18c-R Header". I was on somewhat of a budget, but I chose the Hytech Replica header. Others in this section of the forum can give you better suggestions. It seemed like the top 5 were SMSP, a real Hyetch, Toda, Skunk2 and even a JDM ITR header.
Supertech valves=fail. The heads always prematurely snap off because they under cut them, which produces no real flow gains anyway.
Get arp rod and main bolts and you'll be good to go. Just trash the supertech valves. They are nothing but trouble.
Stock valves on NA setups are the only way to fly. Flat faced valves are kinda iffy, Ive read too many things about them adding stress due to added weight from no dished face. Everything else looks pretty solid though. I would look at the RMF narrow rep. as a header choice. Made nice power on my GSR. Performer X mani w/ portmatched TB will make great power as well. Good choice.
The machine shop i got the head assembled by does good work from what i hear. This whole supertech flat face valve failure talk is kind of discouraging.
i guess i could take some pics of the head later.
The pro series yes, tuners no. I run tuners with no problem. I couple of my friends have been through a set of the pro series and they did crack. They switched back to tuners and have no issues.
It seems the whole supertech valves vs. xxxx companys valves is a personal opinion thing. Some people have success and others don't. I have "personally" seen a lot more stories about the heads breaking off than well...success.
If you can make them work and they dont do the typical supertech head falling off thing then go for it and add to the small list of success stories(not trying to sound like a dick)
I just "personally" stay away from them because they undercut them. Don't you think that if undercutting valves improved them honda would have done it? Its obvious it weakens the valve because you remove material away from the head area and taper it off. Just my opinion.
xotic_crx
17
Oct 28, 2014 04:00 AM
CRVRX
Aug 21, 2009 06:42 PM
