93 Accord LX How do I replace a brake proportion valve
Ok I'll bite, remember I can't spell.
It is as easy as it looks. Remove the brake lines, remove the bracket bolt. Install. Bleed brakes.
If you want, use masking tape and mark each brake line with a number or something, so you easily remember which line goes where on the valve. Maybe even take a digital picture as reference for yourself.
Use a 10mm flare nut wrench aka line wrench to remove the lines. Of course, have plenty of rags, paper towels, to catch and clean up the brake fluid.
Where is the bracket bolt? the nuts on the 10mm nuts on the line I can see, but I'm not seeing how the proportion valve is bolted.
voithofer
Oct 7, 2019 02:57 PM
B_Swapped93
Jun 16, 2014 04:53 AM
hefftone79
Jul 5, 2009 04:19 PM
civicnoob
Apr 28, 2009 09:07 AM
