Brake lights don't work (solved)
Well I just realized that my brake lights went out in my hatch(EG). I replaced both bulbs, and still they're not working. The running lights work, just the brake lights do not come on. What do you think? Fuse? Brake position switch?
check your brake light switch on the pedal to make sure its working properly
also check the brake light fuse (no 42/ 20A) if ts blown and if your getting voltage
Edit: forgot, the fuse should be under the hood fuse box
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
Storm13
Sep 14, 2010 07:07 PM
ATLHONDA
Mar 22, 2010 04:34 AM
b16a2pwr
Feb 14, 2004 02:28 PM
