93 si cd player problem
Old Dec 4, 2010 | 10:24 AM
93grayeg's Avatar
Icon2 93 si cd player problem
Ok I recently replaced the heater core in my hatch, I put everything back together but the cd player is not powering on, The cig. lighter works , The fuse under the dash is good I tested it , The BACK UP fuse under the hood is also good, Fuse in the back of the head unit is good as well. Any ideas?
Old Dec 4, 2010 | 10:28 AM
SLURS's Avatar
Default Re: 93 si cd player problem
bump
for
some
music!
Old Dec 4, 2010 | 11:57 AM
93grayeg's Avatar
Thanks
Old Dec 5, 2010 | 01:42 PM
93grayeg's Avatar
help I need music
Old Dec 5, 2010 | 02:05 PM
fv8s's Avatar
did you lose a ground/ power wire? pull the cd player back out and look, not that hard
Old Dec 5, 2010 | 06:15 PM
93grayeg's Avatar
I dont think so , It isnt hacked up back there , its wired right into a plug and play harness , from what I remember it was never grounded to the car it just went into the factory harness
Old Dec 5, 2010 | 07:07 PM
XYRS2LT's Avatar
My 92 did the same thing. Put in another ground for the stereo, unless someone can tell us the location of the ground in the chassis. Mine did it after a paint job. Nothing was touched inside the car just quit working. Thought the stereo went bad. Replaced it same thing, added new ground, BAMO fixed!!
Old Dec 6, 2010 | 08:57 AM
93grayeg's Avatar
I will try that now , Ill get back to you and let you know, Thanks bud
Old Dec 6, 2010 | 10:58 AM
93grayeg's Avatar
Problem solved, Thanks man . I guess something got outta wack in the factory ground. I Grounded the head unit to the chassis and it turned right on.
Old Dec 6, 2010 | 11:00 AM
fv8s's Avatar
like I said not that hard
Old Dec 6, 2010 | 12:25 PM
SLURS's Avatar
bordum kills with no music!
tyler100
Audio / Security / Video
Jan 5, 2008 02:39 PM
old-sk0ol
Jan 12, 2005 05:27 PM
Greenery18
Aug 31, 2004 10:05 AM
damion911
Mar 3, 2004 11:14 AM
