B18c1 ca smog referee question
Old Dec 4, 2010 | 10:24 AM
sleepydragon636's Avatar
Default B18c1 ca smog referee question
I brought a 95 civic with b18c1 swap. The head is stamped for 93 and the block came with paperwork for 97. Ecu is obd1 gsr. Can this be ca state reffed?
Old Dec 4, 2010 | 09:06 PM
BC_Garage's Avatar
Default Re: B18c1 ca smog referee question
You're block is def cool but im not sure about the head. If they don't inspect the head you should be good but the only way to BAR it is have the motor of the same year or newer. You might need to swap heads to a 97 GSR
Old Dec 5, 2010 | 02:37 AM
dankman's Avatar
cannot be state reffed due to the year of the head.
unless somehow the technician doesn't check all the VINs... but thats highly unlikely.
Old Dec 5, 2010 | 08:50 AM
I was hoping they just go off the block. I asked a few people and they said if I'm lucky ref won't notice it.
Old Dec 5, 2010 | 09:46 AM
4stagecandy's Avatar
i have bar'd many cars they dont check the cast year on the head, you dont need any paper work for the motor
and to dankman what you posted makes no sense even if they do check all the vins what does that have to do with the head, heads never came with a vin any year
Old Dec 5, 2010 | 11:24 AM
Can my engine be bared for obd1 even though it's a 97.?
Old Dec 5, 2010 | 01:05 PM
ekb16's Avatar
same yr or newer so ur good to go
DR.P3PP3R
Sep 15, 2010 01:57 PM
teggy1.7
Jul 22, 2008 05:55 PM
ekb16
Jul 9, 2008 03:28 PM
jmpgraphy
Aug 26, 2007 03:57 AM
B16Hatchcx
Aug 1, 2003 08:43 AM
