Doesnt start! HELP!!!
Old Dec 3, 2010 | 11:04 PM
CivicTec's Avatar
Default Doesnt start! HELP!!!
Hi guys.
I have a b16a this morning about to leave for work for car didnt and still doesnt want to start it just swings.
Normally when I put the ignition on the engine light goes on the it would make a like a click sound and go off, I noticed this morning it didnt make that sound. I dont a damn know where to start looking for the problem?
It was driving fine last night.
Old Dec 3, 2010 | 11:30 PM
PunkRudeBoy's Avatar
Default Re: Doesnt start! HELP!!!
Check the battery?
Old Dec 3, 2010 | 11:59 PM
CivicTec's Avatar
Originally Posted by PunkRudeBoy
Check the battery?
Not the battery, there is power the car does swing.
Old Dec 4, 2010 | 03:58 AM
foo fighters's Avatar
check CEL? year,make,model? coil??
Old Dec 4, 2010 | 10:22 AM
SLURS's Avatar
bump
Old Dec 4, 2010 | 05:35 PM
ej1 rep's Avatar
This helps a lot
http://www.b20vtec.com/forums/b-seri...sis-101-a.html
Old Dec 5, 2010 | 01:43 AM
CivicTec's Avatar
Okay so I still had no luck these are the things I have tried and tested.
1. There is petrol coming through.
2. There is no spark.
3. I tried a different dizzy.
4. I cleant the relay abit and sprayed Q20 on the points. Before I done this the engine light was off and wouldn't come on at all. After I cleant it the engine light now stays on as soon as I switch the ignition on and doesn't go off. I checked to see if theres any ecu codes but it doesnt throw out any codes.
5. I checked all fuses and all is fine.
6. Checked all plugs in the engine bay.
7. Unplugged ECU srayed Q20 on all points and made sure they all making proper contact.
8. Tried different spark plug wires.
9. Thought is could be the alarm so I bypassed the alarm also.
10. Disconnected battery terminal to reset ECU.
Now I am totally lost.
Oh. Its a 1998 pre-facelift EK b16a6 motor. It has the OBD2a ECU.
Old Dec 5, 2010 | 07:46 AM
z0mby's Avatar
Are you getting fuel?
Old Dec 5, 2010 | 08:55 AM
ej1 rep's Avatar
Yes he is gettting fuel! thats what petrol is.
Sounds like you should concentrate on the no spark issue. Was the distributor you put in new or used or remaufactured?
resqu417
Honda Civic (2001 - 2005)
10
Dec 17, 2009 05:35 PM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
Jap_Spec_Imports
Sep 24, 2006 11:16 AM
MikeM324
Dec 20, 2005 05:36 AM
boosh
13
Jan 2, 2004 02:33 PM
