cutting radiator frame.. that cutting tool?
Old Dec 3, 2010 | 01:01 PM
Charlie Moua's Avatar
Default cutting radiator frame.. that cutting tool?
I need to do some cutting of my front radiator support frame.
What is the best way of cutting this? (black marker....) lol
- recipricating saw
- dremhel with router bit
- circular cutting bit with drill
- cutting torch... jk
Old Dec 3, 2010 | 02:14 PM
TunerN00b's Avatar
Default Re: cutting radiator frame.. that cutting tool?
Old Dec 3, 2010 | 02:42 PM
.Manny.'s Avatar
Touching My Member
^that, then a dremel to clean it up. yeeeaaah!
Old Dec 3, 2010 | 04:08 PM
raffaelli's Avatar
Kinda looks like the scene of an accident!
Old Dec 3, 2010 | 06:11 PM
1990hondacrx's Avatar
if you have to ask how to cut it out maybe you shouldn't be even handling a power tool!
Old Dec 3, 2010 | 06:30 PM
radex7's Avatar
You are forgetting a 4"-5" right angle grinder with a cutoff wheel. If you have Harbor Freight near you that is well spent $25! You will be done in no time and you can just switch the wheels to clean it up.
Old Dec 3, 2010 | 08:30 PM
yes i love harbor freight tool... thanks guys
Old Dec 20, 2010 | 01:43 PM
all done
$30 dremhel at walmart and a router bit for $6....
cut through pretty easily... now I just have to sand it down with a wheel to make it smooth.
I'll probably glue some ruber molding around it just to prevent any damage to the FMIC piping should it come off or get bumped.
1fastVX
Welding / Fabrication
19
Jun 28, 2005 02:55 PM
JDM EJ1 95
Dec 28, 2004 10:39 AM
slvrcivic97
Dec 26, 2003 06:59 PM
integra0260
Jul 26, 2001 02:22 PM
