Please look, need advice on eg cx rust
Old Dec 3, 2010 | 07:49 AM
g35silversurfer's Avatar
Default need advice on eg cx rust, Should I be happy?
I have a 95 cx
was manufactured in Canada
I live in Arkansas, got this hatch last fall.
it's clean title, never been in any accidents, no bondo, 3 owners,
original paint, not riced out, taken care of- all those are hard enough to find.
with little rust bubbles on rear wells,etc...
Anyhow, I've put a lot into this build, but it's all stuff I could easily take off and put into another hatch.
My problem is, to find a hatch with absolutely zero rust, is near impossible, because half has been re-painted, therefore, probably had some before,
or if it has none, it hasn't been fully inspected in which, a little would probably present itself.
So, with that in mind, I should probably just keep my hatch, and get all the rust fixed, and keep this car forever
The other day I took out all the interior again, sideskirts,
today I took off the rear bumper and inspected.
I took pics of everything. I want opinions on my rust,
usually when the wheel well is rusted, the lower part underneath the
plastic side skirts will be ruined with rust.
Mine are beautiful looking. except on the rear passenger side,
My floor driver side rear had a rust corner (as if liquid puddled up there) and
it just ate right at that one spot and only traveled up a body seal seam as you will see.
other than that there's the little rust right around the wells.
not horribly bad.
I have the rust panel quarters already when I got this hatch they came with it.
Anyone who has fixed, repaired, or seen honda rust on a hatch,
Please give me advice. Should I just get the rust fixed, or
ditch this shell. It's very hard to even find a clean shell, if you can even
find someone selling one.
Any and All info would really help me out.
There's the photobucket link with several detailed pics I took of the rust.
I also wire brushed it all and put rust primer over it just to help keep it
stopped from getting worse until I get it to a body shop.
Just veiw it as a slideshow.
http://s785.photobucket.com/albums/y...c%20cx%20rust/
here's two links of threads about fixing the rust, and i've studied these
a ton, I just want ppl to see mine and give me advice from their experience.
http://www.civic-eg.com/viewtopic.ph...er=asc&start=0
https://honda-tech.com/forums/appearance-build-threads-122/eg-project-95-civic-si-rust-bucket-2398771/
Old Dec 3, 2010 | 08:22 AM
94EG8's Avatar
Seagull Management
Default Re: need advise on eg cx rust please
Biggest thing I can tell you is bodywork is just plain tedious. Good thing is yours has very litttle rust, my hatch is bad enough that i'm getting another shell (quarters are rotten, way up into the door pillar, rockers are non existant, driver's seat is going through the floor etc.) I will say use lots of good 3m seam sealer on your welds inside the car and then spray the inside with rust check, krown etc. Oh, and beg, borrow or steal a sandblaster, you can wire brush and grind rust all you want, but it'll still be there, sandblaster takes car of it quick and easy, doesn't need to be big either, just a small blaster and some zero sand does an awesome job.
Old Dec 3, 2010 | 11:19 AM
jasoncrashtech's Avatar
Default Re: Please look, need advice on eg cx rust
you need new quarter panels and a lot of work on your floor pan. if you try to fix those spots it will most likely come back in the near future. the area's if the pic's are very hard to to get to so getting all the rust out isn't likely plus there is a good chance there is more rust eating through that you can't see.
patching those panels could end up a waste of money for you. this car looks like its been through flood damage
Old Dec 3, 2010 | 11:25 AM
well i'd be getting the panels replaced, I already have the replacement panels for it.
i'd be having all metal cut out and replaced.
the places arent that great to get to, but in the other thread links, they had to do the same thing and it looked like they got rid of all the rust just fine...
have you done this before to a civic?
Old Dec 3, 2010 | 11:29 AM
yes. i'm a autobody tech.
Old Dec 3, 2010 | 11:32 AM
do you have used panels ? using used quarters might also come with floor and wheel house pieces that could come in handy
Old Dec 3, 2010 | 01:36 PM
Pothole987's Avatar
Lol this is typical though near salt water.
all i can say is take your time with metal work. I just had to fix a spot on the quarter of my 98, there was a little spot of rust, i accidentally hit it with a shopping cart today and put a hole through it :s i was sour but fixed it up perfectly for now! i cut out all the thin brown crap metal and sand blasted around it and then welded in 2 pieces to fix it. all i can say it completely repair it dont half *** anything.
Old Dec 3, 2010 | 01:41 PM
i have brand new panels that you can buy for swapping the quarters.
you'd just have to see them to see what I'm talking about.
like these:
http://cgi.ebay.com/ebaymotors/92-95...Q5fAccessories
this hatch hasn't had flood damage, If your familiar with 92-95 civics, you'll know that
the rear quarters are known for being horrible about producing rust.
Once they start to rust, it travels down and up, hence, Why I have rust in the seams going up to the taillight and down to the side skirt.
if you look at the other links I put , they both had 10x more rust and way Way worse than I do. and they still fixed theirs.
So, I know it can be fixed.
I'm just looking for ppl who have fixed theirs before to voice in their thoughts about my rust and my hatch.....
Old Dec 3, 2010 | 01:47 PM
My plans are to take to someone who will do this for me,
since I don't have a big garage, or any of the expensive tools, or much experience haha.
take it all apart, tail lights, bumper, etc.....
and have it all fixed, then spray rust-mort into every hard to get place.
that stuff stops rust from spreading.
I saw a guy who had rust, and just wanted it to stop til he fixed it,
it's been 4 yrs and he hasn't had it spread at all, killed it.
so if I get it all fixed, and then spray that crap everywhere, that should keep me rust free....
Once again, Looking to hear from ppl who have done this whole thing
Old Dec 3, 2010 | 03:47 PM
oh ok, nevermind. good with the patch panels. lol
Old Dec 3, 2010 | 05:27 PM
94EG8's Avatar
Seagull Management
It was originally a nova scotia car so chances are it was around salt water at some point. Its really bad though. I know a guy that brings back rust free truck boxes from the southern states, he's going to get me a shell, figured I might as well start fresh.
Old Dec 3, 2010 | 05:53 PM
my car was manufactured in canada, not built and sold in canada. it went straight to a honda dealership in like ohio or somewhere in the US.
you really think My rust is "that" bad?
Old Dec 4, 2010 | 05:55 AM
wish I could post this in parts thread or something haha. maybe i'd get some advice.
Old Dec 4, 2010 | 06:13 AM
94EG8's Avatar
Seagull Management
No no, I was referring to my own civic, yours is fine, its very fixable.
Old Dec 4, 2010 | 02:18 PM
what do I do about the area under the rear speakers? where it just looks dirty and maybe a few small rust bubbles, do I use rust converter?
what do I use to get where I cannot reach to replace metal?
I've been doing tons of research, I'm going to get my quarters and all rusted metal replaced, but for all the spots that cant be reached, should I use rust converter?
rust mort , picklex??? any help would be great.
Old Dec 4, 2010 | 02:45 PM
94EG8's Avatar
Seagull Management
Sandblast it if you can and seal it up with something (primer > primer sealer > paint preferably)
Old Dec 5, 2010 | 05:41 PM
bump.
egjdmcivichatch
Jul 29, 2013 07:38 AM
g35silversurfer
Dec 4, 2010 07:05 AM
morgan@synapse motorsport
Feb 19, 2006 05:09 PM
hatchsnatch
Feb 25, 2004 05:16 PM
Guam_CiviC619
Jan 6, 2004 06:34 AM
