OBD1 distributor with OBD0 computer. HELP!!!
Old Dec 2, 2010 | 05:58 PM
88EDHatch's Avatar
Icon3 OBD1 distributor with OBD0 computer. HELP!!!
Ok so to say the least I have a 91 hatch with a D15b vtec swap ghetto as hell. The distributor on it is from a D16A6. So it doesnt line up. Well the distributor shaft seal went bad and is pouring oil now. So I have been looking into distributors and ive found out that the Z6 distributor will work and my buddy has one he is giving me, However someone informed me that I cant run the z6 distributor with a jumper harness because Im still running a pm6 ecu. My vtec is on a toggle switch right now(told ya it was ghetto) so im not worried bout getting a p28 right now. I dont have the money to do a obd1 conversion. What can I do? Can I run this distributor with a jumper for now?
Old Dec 2, 2010 | 06:38 PM
EF ridin 4 Life's Avatar
Default Re: OBD1 distributor with OBD0 computer. HELP!!!
as far as i know you cant run a OB1 dizzy with 0bo ecu...theres no way around it..maybe get a non vtec ob1 ecu for cheap and just chipp it later..car will run lik shitt though with wrong ecu...good luck man
Old Dec 2, 2010 | 08:29 PM
BrandonR's Avatar
You can remove the A6 distributor internals and put them in the Z6 housing. Thats the only "quick & cheap" solution I can think of. -Later, BR
Old Dec 2, 2010 | 11:02 PM
crx_si-r's Avatar
or make it easier on yourself. replace the seal or o-ring (o-ring normally goes bad and causes the leaks) and trim the ear (mounting tab) and rock if obd0 until you get all your obd1 conversion parts and run the motor right.
Old Dec 3, 2010 | 01:35 AM
HondaPartsHero's Avatar
Technical Hero
This won't work, the internals are not the same from OBD0-1/2
Old Dec 3, 2010 | 05:13 AM
88EDHatch's Avatar
So I cant do it. Well if money wasnt a prob I would go ahead and do the obd1 swap but im jobless and my car is a dd.
As far as the seal goes I have went to the honda dealership and they cant order it. Its got a brand new O-ring.
Do I have any onther options?
Old Dec 3, 2010 | 08:57 AM
outkastef's Avatar
not sure if it helps but my car has a d15b7 from a eg and i have a jumper harness and obd1 ecu and original dizzy for the motor. as far as i know it only ran about $150 for the jump harness and ecu but the ecu was found on cragslist
Old Dec 3, 2010 | 10:02 AM
Technical Hero
http://sites.google.com/site/hondali...ributorbearing
http://thezcr.com/forums/showthread.php?t=12945
BuGz32crx32
Sep 23, 2008 10:43 PM
slimer1
Apr 4, 2005 09:06 AM
willyboyK20
Jan 23, 2005 07:25 AM
