1991 civic hatch
Old Dec 2, 2010 | 05:53 PM
gnxpro24's Avatar
Default 1991 civic hatch
another dumb question just because I need to make sure befiore i sell my transmission. the 5 speed lx transmission will replace a a speed dx one without using different mounts (using the original dx mounts). also are the first 4 gears of the lx transmission the same as the 4 of the dx 4 speed, but with a 5 gear added for overdrive for gas mileage? or are the 4 speeds faster?
Old Dec 2, 2010 | 06:00 PM
88EDHatch's Avatar
Default Re: 1991 civic hatch
I believe only time gearing is changed in 4th gens was for the SI. And the mounts should be the same. Just make sure the flywheel is the same. I believe there was a difference on them size wise
Old Dec 2, 2010 | 06:15 PM
gnxpro24's Avatar
so the 4 speeds didnt have tighter gearing? anybody? and anybody no if the flywheel is the same?
Old Dec 2, 2010 | 11:05 PM
hatchet_honda's Avatar
flywheel goes by year. not if its 4 or 5 speed. 88's had smaller flywheels then the other years
Old Dec 3, 2010 | 11:27 AM
gnxpro24's Avatar
what about gear ratios
Old Dec 3, 2010 | 11:56 AM
90_EX_Civic's Avatar
http://crx.honda-perf.org/math/index.html
another
http://crxcommunity.com/viewtopic.php?t=246
here's one thing. there is a site that gives out all the gear ratios don't remember it. and you should look it up. the info is out there. don't be lazy.
Old Dec 3, 2010 | 12:11 PM
jlk16188's Avatar
the 4 speeds had diff gear ratios than the 5 speeds. the 4 speed has taller gears. dx, lx and si trannies all will be much faster than your 4 speed
Old Dec 3, 2010 | 12:33 PM
gnxpro24's Avatar
so which gets better gas mileage lx 5 speed or dx 4 speed
Old Dec 3, 2010 | 12:57 PM
made for cali HF 5 speed. really long gearings.
Old Dec 3, 2010 | 01:09 PM
gnxpro24's Avatar
so wouldnt that make the lx 5 speeds slower?
Old Dec 3, 2010 | 03:50 PM
by slower you mean longer?
lx,dx, si, and ex 5speeds have the same gear ratio. the si/ex have a shorter final drive.
im not completely sure if the hf has the same gearing (non cali models) but for sure there final drive is even longer then a lx, and dx.
for the 4speed, i don't remember correctly, but i think it has the same final drive as the dx, and lx. of course the gearing is different.
Old Dec 4, 2010 | 09:24 AM
gnxpro24's Avatar
I dont have to use a 5 speed ecu to run the 5 speed in a 4 speed dx shell do I? will 4 speed dx ecu run it
Old Dec 4, 2010 | 10:13 AM
jlk16188's Avatar
ok i need to clear you up here. Now beware, i am not comparing the actual gear ratios vs final gear size. I am simply clearing up what you as a driver will feel or experience by changing stock trannys
the 4 speed is not a dx, its an std model
dx trannys have 5 forward gears
hf has the tallest "longest" gears making it the slowest
dx/lx has shorter gearing but still gets good mileage with faster acceleration
ex/si has the "shortest" gears which gives you the fastest acceleration
if you want the best acceleration buy an si or ex trans
if you want the best gas mileage then buy an hf trans
still somewhere in between? then buy a dx or lx...prob wont feel much difference if any between the 2
if you really want gas mileage and youre on a budget, keep the 4 speed but accept the fact that your acceleration will suck.
I live 50 miles from you and own a 4 speed civic and a dx 5 speed crx. the civic sucks to drive up and down the hills in the area, the dx tranny is much better and gets the same gas mileage
that tranny is not controlled by your ecu. run the correct ecu for your engine
Old Dec 4, 2010 | 01:41 PM
EX/Si don't have a shorter gearing, it's the same as a DX/LX. The FINAL drive is different.
http://forums.hondashowoff.com/showthread.php?t=8831
Old Dec 4, 2010 | 04:19 PM
jdm ef8 89's Avatar
You know what he means by short geared tho.
Old Dec 4, 2010 | 05:04 PM
jlk16188's Avatar
read the warning i posted in my reply, i specifically said im not comparing the actual gear ratios...i didnt want to get too technical bc he obviously isnt quite understanding what we are talking about what we say tall or long vs short
Old Dec 4, 2010 | 05:56 PM
gnxpro24's Avatar
I know what you mean tho. and the transmission is in a 91 dx its a 4 speed so how isnt the dx a four speed. I believe on the sedans were dx 5 speeds
Old Dec 5, 2010 | 04:14 AM
jlk16188's Avatar
hatchbacks had the option of being an std model with 4 speed. its not a dx tranny. stds do not have center consoles, pass side mirrors, no tach and a black center tail light garnish. they have d15b1 motors with dpfi. check it out or post some pics up
Unless yours was a dx and someone swapped the tranny, you are mistaken
Old Dec 5, 2010 | 06:11 AM
gnxpro24's Avatar
Oh I always thought when people talked about std models it meant dx that explains everything thanks for the info
Old Dec 5, 2010 | 07:07 AM
jlk16188's Avatar
nope dx means dx and std means not dx
Old Dec 5, 2010 | 08:40 AM
asianflava's Avatar
std = base model
Old Dec 5, 2010 | 08:53 AM
gnxpro24's Avatar
was it only hatchbacks that came in std? what about wagons and sedans?
Old Dec 5, 2010 | 09:06 AM
jlk16188's Avatar
only hatches were stds
paradigm_shift
Aug 16, 2009 10:19 PM
San Angelo
Transmission & Drivetrain
Nov 1, 2008 06:46 PM
03EM2_EX
Nov 4, 2006 10:53 AM
Jonathan_ED3
Apr 28, 2003 10:45 AM
austrian type-R
Sep 19, 2001 05:24 AM
