Which Wire Harness is needed? +ECU
Old Dec 2, 2010 | 12:14 PM
SoFresh's Avatar
Default Which Wire Harness is needed? +ECU
Ok, so I have a 2000 Civic SI with the stock B16 and stock ECU.
Engine harness was stolen. So, question is... I plan on boosting the B16 in a month or so. I need a new engine harness. I read that an EX harness will work, assuming 99-00 only however?
I have OBDII, I heard I need to swap to OBDI for tuning when I go turbo, is this true? If so...
1. which harness should I buy?
2. would I need a jumper harness?
3. which ECU do I get?
Sorry if this is a noob question, I've been researching it for hours and its just confusing the fawk out of me! lol
I do have my stock 00 SI harness all cut and spliced up, the one stolen was a Rywire harness since I have a full tuck in the engine bay... I am trying to avoid spending $300-500 for a tuck harness again. Suggestions. Thanks in advance.
Old Dec 2, 2010 | 12:58 PM
2point1's Avatar
Default Re: Which Wire Harness is needed? +ECU
you need a stock 99-00 civic ex/si obd2b engine harness,an obd2b to obd1 jumper harness to use the obd1 ecu in your car for when you get tuned and a p28 ecu..
Old Dec 2, 2010 | 08:25 PM
SoFresh's Avatar
thank you!
Old Dec 2, 2010 | 09:24 PM
mouab18c1's Avatar
I have a chipped p06 converted into a p28. $110 shipped if you want it. LMK
Old Dec 3, 2010 | 04:24 AM
kyden's Avatar
99-00 ex will work, but you'll have to rewire the distributor plug.
Torleif
10
Aug 20, 2015 05:29 AM
clark81
Sep 5, 2010 11:52 AM
Jdmdctek
Jun 11, 2007 07:55 AM
DarkSol97
Aug 13, 2005 08:37 PM
