Choosing between Rear UPPER strut bar or Rear LOWER strut bar.
Old Dec 2, 2010 | 08:54 AM
trojan's Avatar
Default Choosing between Rear UPPER strut bar or Rear LOWER strut bar.
hi guys..i own a 95 civic and decided to buy a front and rear strut bar. i am thinking of buying megan racing. what do u think its best to install between the rear positions..the upper or the lower?
thanks Troy
Old Dec 2, 2010 | 10:35 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Choosing between Rear UPPER strut bar or Rear LOWER strut bar.
Do you have a swaybar?
If you don't get that first.
1/2 the people you ask will tell you chassis reinforcement bars don't do anything. And if you're buying one megan racing isn't a rolling force of engineering accomplishment.
If you have to get one get whichever one impedes the function of your car the least.
Old Dec 8, 2010 | 11:30 AM
trojan's Avatar
no mate..dont have swaybar..i make that first?
Old Dec 8, 2010 | 11:35 AM
Pothole987's Avatar
Yes.
Old Dec 8, 2010 | 12:51 PM
variable's Avatar
I think you should get subframe reinforcement and a ITR rear sway bar first
Old Dec 8, 2010 | 04:34 PM
ownedevo10's Avatar
Yea like the guys said already def get a sub frame brace with a sway bar.. Look at ASR they make a really nice sub frame brace and I think they sell a combo deal with a sway bar.
Old Dec 8, 2010 | 06:32 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
What everyone else has been saying.
A rear sway bar helps eliminate understeer. The subframe brace will keep the sway bar from damaging your sub frame.
Old Dec 8, 2010 | 06:56 PM
Deetz's Avatar
Crazy Honda Guy
A rear sway bar will make a "huge" difference in performance. Also, by using a subframe brace along with it, the rear end is strengthened much more than any bar, as well as prevents any chance of a tear out due to greater stress running a larger rear bar
Old Dec 8, 2010 | 08:03 PM
faztec1's Avatar
All the above is true but you also got to consider price. A brace reinforcement and sway bar is not really cheap.
Old Dec 9, 2010 | 02:20 AM
Ek Forever y0!
Progress auto sells a 22mm rear swaybar that doesn't require a reinforcement brace. The kit comes with reinforced mounting equipment to prevent tearout.
I've got their swaybar kit sitting in my living room waiting to go on
I've asked them several times about a reinforcement kit for it, and every time they say not only is it not needed with their bar, but most Tie bars/ASR kits wont fit with their hardware.
Old Dec 9, 2010 | 03:34 AM
Deetz's Avatar
Crazy Honda Guy
I paid $300 for the above setup, not a bad price, i do not consider that expensive.
My other EK i went used with a SSR or M-Factory style 19mm sway w/brackets...total cost $40....there are many options if you just use your head a little
Old Dec 13, 2010 | 09:23 AM
trojan's Avatar
thanks guys for this info! respect
s2k_3.11
Feb 28, 2007 05:45 PM
Try2Live4God
Feb 23, 2005 06:41 AM
IntegraPrez
Oct 9, 2004 09:08 AM
130R
Jun 8, 2004 05:34 PM
