Suspension & Brakes Theory, alignment, spring rates....
93 EG Hatch suspension upgrades from 95 EX
Old Dec 2, 2010 | 08:29 AM
big_tiger's Avatar
Default 93 EG Hatch suspension upgrades from 95 EX
I purchased a totaled (in the rear) 95 Civic EX, and spent a week stripping everything of use for my hatch. I will slowly swap parts over, and I want to start with the front sway bar. I know I need to swap the control arm, but with the rubber its old and needs to be replaced.
Question is should I replace with OEM rubber or poly? The car will be street driven and really be just a daily, so I wont be taking it the a track anytime soon. It just hard to not buy upgrades
Next will be the EX brakes.
Old Dec 2, 2010 | 09:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 93 EG Hatch suspension upgrades from 95 EX
HardRace rubber bushings. Cheaper than OEM, MUCH cheaper than Mugen rubber, and will last way, WAY longer than polyurethane.
Old Dec 2, 2010 | 10:49 AM
big_tiger's Avatar
Even though I work at a dealership the oem bushings are still a little too rich. Websense must own there site, because I can't load hardrace.com
Old Dec 2, 2010 | 11:35 AM
Community Builder
www.buyhardrace.com
Old Dec 2, 2010 | 02:01 PM
big_tiger's Avatar
Little strange. On the site you linked to they dont have sway bar mounts (just links). I go to hardrace.com and they have them... $60 for the links I think is too much for what I actually will do with this car.
Old Dec 6, 2010 | 07:53 AM
AutoShepherd's Avatar
If the money is tight, and the stock ones look okay, I would just use the stock ones, IMHO.
Old Dec 6, 2010 | 09:31 AM
90_EX_Civic's Avatar
you know you don't need to replace the whole control arm. if you look carefully you only need the part that the sway bar bolts to. then the D clamps, pretty sure you can just bolt them up with the EX hardware.
NewCarSmell_EX
Mar 19, 2018 07:38 AM
Jon Petersen
Feb 11, 2018 11:15 AM
Drew2o2
Suspension & Brakes
Aug 4, 2010 09:17 PM
z6civicex
Suspension & Brakes
Dec 4, 2006 09:21 PM
ek hatchhh
Apr 5, 2006 10:40 AM
