Redoing my head gasket HELP
Old Dec 2, 2010 | 06:37 AM
honda_ek9's Avatar
Default Redoing my head gasket HELP
Hey I am planning on replacing my headgasket and headstuds and maybe doing my water pump and timing belt replacement since im already taking off the head..So Can You Guys Please Help Me..(head is leaking alittle bit, trying to prevent this leak)
GSR Head
Ls B18b Bottemend
What kinda Headgasket should I get?? I heard oem headgasket is better then cosmetic. Is that tru?If so What kind of Gasket should I get Since my head is a GSR head with a B18b Bottom end...Gsr head gasket or Ls Gasket??
And for headstuds what kind should I get so that my head will stop leaking...
And for water pump and timing belt i have no idea on what to get that will work on my setup. (My belt on my motor right now is loose and when its warmed up it gets tight but still little lose) tried tightening is already but its already to the fullest..Scare that my timing belt might snap since its seems lose..unless its suppose to be like this..
Thanks
Old Dec 2, 2010 | 06:48 AM
kyden's Avatar
Default Re: Redoing my head gasket HELP
golden eagle headgasket. vtec water pump and gsr/itr belt.
you need to figure out why your head is 'leaking' or you'll just end up doing another one again.
Old Dec 2, 2010 | 07:21 AM
honda_ek9's Avatar
For the golden eagle headgasket- should it be a gsr head gasket or a ls headgasket??
once i take off the head then ill see what is causing it to leak..cause it only leaks in the front of the motor..
Old Dec 2, 2010 | 08:20 AM
kyden's Avatar
golden eagle only makes 1 kind.
Old Dec 2, 2010 | 09:16 AM
honda_ek9's Avatar
o lol..my bad didn't know that..Thanks
gratua
Feb 17, 2012 06:12 PM
1slow02
Sep 30, 2009 10:05 PM
b20steveo
May 3, 2009 08:51 PM
nomoreavril
Apr 6, 2008 08:41 PM
TooManyTickets
14
May 27, 2007 03:05 PM
