93 hatch/OBD2 jdm d15b wont start and throwing code 16
Old Dec 1, 2010 | 05:08 PM
Eg_Justin!'s Avatar
Default 93 hatch/OBD2 jdm d15b wont start and throwing code 16
just put a jdm d15b in my hatch and i wont start and im throwing code 16 (fuel injectors) i don't know y im throwing this code any ideas?????????
Old Dec 1, 2010 | 05:46 PM
Rylan's Avatar
Default Re: HELP!!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Should always post specific details of what car your talking about.
Maybe check the voltage going to your injectors, and if they come back good.... Try popping them out and giving them a good clean?
Old Dec 1, 2010 | 05:53 PM
Former User's Avatar
Originally Posted by Rylan
https://honda-tech.com/forums/showthread.php?t=2809571
^This and create a good title (edited).
And also resolder the main relay.
Old Dec 1, 2010 | 06:32 PM
Eg_Justin!'s Avatar
Default Re: jdm d15b wont start and throwing code 16
its a 93 hatch that has been converted to obd2 and i put in a obd2 jdm d15b with a y8 intake mani and im using a gsr ecu cuz its the only one i had... it wont start just keeping turing over its throwing code 16
i replaced the main relay and check spark, timing, and it gettin fuel all the way throw the fuel rail to the return line... i had a set of injectors so i swapped em out and still no start
any other ideas????
Old Dec 1, 2010 | 06:47 PM
If you reset the ECU, does code 16 return after cranking the engine for 20-30 seconds? Are the injectors spraying fuel?
Is spark bright white at the plugs?
Are the plug wires installed in the correct firing order on the distributor cap?
Have you checked the mechanical timing?
Old Dec 1, 2010 | 07:00 PM
Eg_Justin!'s Avatar
Default Re: 93 hatch/OBD2 jdm d15b wont start and throwing code 16
yes wen i reset the ecu it goes away at first then wen i start cracking it comes back..
im not sure if the actual injectors r spraying fuel but fuel goes to the return line ill check on that tomorrow im dun for tonight...lol
the spark is bright white...
i check the firing order it is right..
the timing should be fine motor came out of a running car but ill check it again tomorrow after i get out of work..
thanks bro for ur advice
Old Dec 1, 2010 | 07:13 PM
If the injectors are not spraying fuel, start here:
Old Dec 5, 2010 | 01:00 PM
Eg_Justin!'s Avatar
ok i had some time to work on my car and the injectors are not spraying fuel but fuel is going throw the fuel rail?
Old Dec 5, 2010 | 01:13 PM
delsolo95's Avatar
did you check the voltage on your infectors? injectors are controlled electronically so it opens and closed during operation. it may be stuck closed.
Old Dec 5, 2010 | 01:25 PM
Eg_Justin!'s Avatar
how do i check the voltage?
Old Dec 5, 2010 | 02:31 PM
Eg_Justin!'s Avatar
ttt
Old Dec 5, 2010 | 02:38 PM
Eg_Justin!'s Avatar
and what is it suppose to be???
Old Dec 5, 2010 | 03:30 PM
Eg_Justin!'s Avatar
bump
Old Dec 5, 2010 | 09:59 PM
Eg_Justin!'s Avatar
Old Dec 6, 2010 | 07:20 AM
foo fighters's Avatar
buy a chilton guide!
ED3Sleeper
Oct 27, 2011 06:03 PM
{EF9} GrEaZe m0nKeY
Aug 12, 2009 09:26 PM
bgcrx
Feb 21, 2008 07:24 PM
SupraRXZ
Apr 6, 2006 09:48 AM
