?? What hose/vaccum is this?? B16's Chime in...
Old Dec 1, 2010 | 11:57 AM
305civictyperaw's Avatar
Icon2 ?? What hose/vaccum is this?? B16's Chime in...
Originally Posted by 305civictyperaw
Any1 know where this hose is supposed to go??
Its right next to the intake mani, under my dizzy on my B16A..
a better pic i found online...
i removed what was left of the hose and here's what it looks like.
i was told it goes to the FAST IDLE THERMAL VALVE but i cant find any open connections. this morning when i was letting the car warm up before comin to work i noticed the RPM's jumped to 2K randomly and stayed there (this had never happened before)... then the car started overheating so this is the first hose i saw leaking. please help
Old Dec 1, 2010 | 11:58 AM
Default Re: ?? What hose/vaccum is this?? B16's Chime in...
I also picked up a rubber plug .. i was wondering if its safe to plug this up?
i read on another thread that u dont really need a FAST IDLE THERMAL VALVE? True or False?
Old Dec 1, 2010 | 02:35 PM
bump
Old Dec 1, 2010 | 02:40 PM
Linked's Avatar
it looks like it is for the FITV
people bypass it to keep intake air cool,
depending on where you live its safe to do, but without it, your throttle body valve can freeze in place if your enviroment is too cold
Old Dec 1, 2010 | 02:58 PM
i live in miami where the lowest we hit is 45degreez LOL. so i can just plug it with no problem correct?
Old Dec 1, 2010 | 03:21 PM
Linked's Avatar
the way people do it is to bypass them, get a hose coupling, idk what its called, and connect that hose to the U-shaped hose you see in the 2nd pic. plug the FITV with a bunch of napkin or something
reason being so you keep coolant flowing through the iatv and corrosion from forming
Old Dec 1, 2010 | 03:27 PM
Mad-Mike's Avatar
Dumb question but is that vacuum line on a b16a2? Cause I thinking I got a leak in that line and was wondering if anyone could point it out on hondapartsunlimited?
Old Dec 1, 2010 | 03:41 PM
Linked's Avatar
they arent vacuum lines, their coolant lines.
if you got a vacuum leak try to take pics and make a new thread
Old Dec 1, 2010 | 04:49 PM
ok so i blocked the nozzle where this hose used to go and drove home from work.
i left the car idling in the driveway for about 5mins to see if it overheat or if any coolant leaked but nothing. everything seems to be okay for now -____-
Old Dec 1, 2010 | 04:50 PM
BTW im running a B16A swap in my hatch
Old Dec 2, 2010 | 05:01 AM
bump. i keep getting ppl say the hose goes to the FITV.. does any1 have a pic of the exact fitting it goes too????
Old Dec 2, 2010 | 07:34 AM
Linked's Avatar
im almost sure those are the coolant lines for the FITV, seeing as the other coolant line runs back around to the IACV and thats a coolant line, i believe its either a 3/4" or 5/8" fitting that you can use to bypass the FITV
Old Dec 2, 2010 | 08:14 AM
thanks LINKED!
integra_101
Dec 19, 2013 11:41 AM
305civictyperaw
Dec 6, 2010 02:02 PM
xshortx
17
Jan 21, 2010 07:57 PM
prayludin
Mar 30, 2005 12:03 PM
