Balancing Slicks on VPD's
Old Dec 1, 2010 | 11:45 AM
JakeSpec's Avatar
Default Balancing Slicks on VPD's
Dumb question but I wanted to Know how many of you add the sticky weights to balance your slicks? i know you cant use the hammer on weights with lensos..
What about tire spin on the wheel?
wouldnt the balance be effected after a couple of launches?
balancing at what Psi?
Im about to pass on it today when i mount some new rubber,
any insight?
Old Dec 1, 2010 | 11:49 AM
Garage 808 Hatch's Avatar
Default Re: Balancing Slicks on VPD's
I had mine balanced, never had tire movement on the wheel down to 6psi. They were spin balanced and used the stick on weights
Old Dec 1, 2010 | 11:53 AM
JakeSpec's Avatar
did you balance at 6psi?
or higher?
Old Dec 1, 2010 | 02:16 PM
SlicksMH's Avatar
Balance the slicks............
SlicksMH
Old Dec 1, 2010 | 02:20 PM
2k.civic.si's Avatar
SlicksMH
Question on how you recommend them to be balanced....what tire pressure? bubble balancer or digital? Is the 35mph the digital ones spin them at fast enough? Just lookin for general info here.
Old Dec 1, 2010 | 02:41 PM
BoostR41's Avatar
one of my slicks moved last year and made the wheel seem bent and pull hard to the left at 130mph, then wiggle when I got on the brakes at the end. Balance the slicks. We balanced mine with the air it took to seat the bead. Used sticky weights and covered them with tape so heat didnt make them come off. I also drilled the wheels and put wheel screws in. Never had a balance problem after that
Old Dec 1, 2010 | 02:48 PM
redboost10's Avatar
we bubble balance everything no matter what type of racing it is.
Old Dec 1, 2010 | 02:56 PM
j-bird20's Avatar
Def Balance them....i had my 24.5's spin balanaced on my lensos. I never ran them without weights so i dunno but i def think there would be a difference not balanced vs balanced. I had about 12 psi of air in the tire when it was balanced. As far as tire spinning on rim. I have alil but i dont think its enough to make a difference. Mark your rim and tire, iff it moves alot, rim screws are in order.
Old Dec 1, 2010 | 03:10 PM
SlicksMH's Avatar
I always ask the racer, what air pressure do you run and bubble balance. I did a test along time ago, 6-psi,10-psi and 15-psi and the weight was the same. Now let's say what (IF) the slicks move on the wheel bead. Mark your slick @ the valve stem with a white marker and if it don't move your fine, and if it did move on the bead it's time for bead locks or rim screws. You can lose 60ft, if it moves on the bead.
Like I said before, if I balance T/F slicks why not yours.
Best of LUCK!!!
SlicksMH
Old Dec 1, 2010 | 03:27 PM
Madmood's Avatar
I have always balanced my slicks and everyone I have built cars for... Its funny the look you get from tire shops that have never done that before.. I figured if my dad balanced his T/F slicks back in the 70's , I should do them too...
Old Dec 2, 2010 | 07:57 AM
JakeSpec's Avatar
Thanks for all the input john and HT members, i will definetly balance them today, im gonna try 10psi on the balance,
cause when you pull down the track my 8 psi shouls be 10-12 so ill stay in that range..
thanks again guys!
Old Dec 2, 2010 | 02:08 PM
mike93eh2's Avatar
i used stick on weights... it took 50psi to seat the beads on lensos. lensos are a pretty tight wheel. i also used glue on the bead to help with tire spin.. they did spin on the wheel a couple inches the first time using them but after that they never did at all.
Old Dec 2, 2010 | 02:28 PM
glue on the bead? seriously? what kind of glue did you use?
Old Dec 2, 2010 | 03:30 PM
welfarepc's Avatar
my MH's spun a little on my lensos at 7psi or less. moved a good inch over 150ish passes.
only down side of lensos i guess... not really safe to screw a cast wheel
Old Dec 2, 2010 | 08:43 PM
AllMotorRandy's Avatar
Through my experience with wheels, try painting the bead seats of the wheel with automotive primer and dry mounting the tires. It will take a little coaxing and a little more psi to seat the beads by dry mounting but it will be worth it. If that doesn't work... you may need to upgrade to some bead lock wheels.
Old Dec 2, 2010 | 09:29 PM
turtleman321's Avatar
Agreed ^^^.
But make sure your have a good tech doing your tires. Don't want a ripped bead on your new slicks
85mmek9
Jan 21, 2010 03:23 PM
Honda Bull
Aug 16, 2005 07:25 PM
CM-R
Aug 31, 2004 11:24 AM
rolow
Nov 25, 2002 03:55 AM
