crx obd0 to obd1 tps question?!
Old Dec 1, 2010 | 09:14 AM
sleeper_status's Avatar
Icon2 crx obd0 to obd1 tps question?!
need some help with a tps question....if i have a obd1 dizzy wired to a obd0 wire harness and converted the ecu to obd1, do i still have to change the two tps wire for the conversion or keep it the same because of the obd1 dizzy...car bogs at full throttle. is it becasue the outer tps wires are switched? any help would be appreciated thanx
Old Dec 1, 2010 | 10:14 AM
crx_si-r's Avatar
Default Re: crx obd0 to obd1 tps question?!
If I'm not mistaken, you ONLY need to swap the wires if your converting your car from a DPFI to an MPFI. other than that it's stays the same.
Old Dec 1, 2010 | 11:41 AM
its converted to mpfi but if you convert it to obd1 do you switch the wires back? its a obd1 dizzy spliced into a obd0 harness and im running a jumper to convert the ecu to obd1
Old Dec 1, 2010 | 11:44 AM
FSRslug's Avatar
No, leave the wires where they are for MPFI when going to OBD-1
Old Dec 1, 2010 | 11:52 AM
even with a obd1 dizzy? its not the a6 dizzy off of the si's like you would usually convert it with, and i changed out the throttle body so idk why it bogs....is it even the tps? the motor is a y7
Old Dec 1, 2010 | 12:28 PM
FSRslug's Avatar
Leave them the way they are.
Old Dec 1, 2010 | 01:01 PM
1990hondacrx's Avatar
check to make sure the tps is calibrated correctly.
Old Dec 1, 2010 | 04:29 PM
2-obd1crx's Avatar
i have a 90 crx with a obd-1 conversion, i used the obd-1 dizzy and did not mess with the tps wires. it runs fine but i deleted the injector resistor box. keep at it bud you'll get it figured out.
Old Dec 1, 2010 | 05:42 PM
meloylo's Avatar
the only differences in the TPS is dpfi and mpfi. once u are mpfi, it doesn't matter whether u are obd0 or obd1 the wires stay the same.
dr_latino999
236
Mar 28, 2020 12:34 AM
munchies91crx
Sep 5, 2009 01:40 PM
90crxef
Apr 6, 2008 06:02 PM
DA9KING
Jul 2, 2007 03:25 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
