problem with del sol cooling system
Old Nov 30, 2010 | 04:08 PM
jonstaub2011's Avatar
Default problem with del sol cooling system
I'm having a problem with my Del sol that has a jdm gsr in it. it doesn't show it warm up on the gauge. The needle goes up but not to where its supposed to be. I've replaced the thermostat like 4 times, 3 from advance and 1 from Acura. I've also replaced the sensors that have to deal with the cooling system. It hits vtec and all and i have heat. I'm thinking that it might be the cluster but i figured i would ask you guys on here first before i bought a new one. Any help would be appreciated.
Old Nov 30, 2010 | 06:13 PM
Former User's Avatar
Default Re: problem with del sol cooling system
If you unplug the temp sender unit under the distributor and ground the plug to the engine, does the needle in the cluster temp gauge rise to the HOT reading? (if so, unground the wire immediately to avoid damaging the temp gauge)
Old Nov 30, 2010 | 07:16 PM
i haven't tried or even heard of that yet. i'll give it a try tomorrow and let you know what it does
Old Dec 1, 2010 | 02:19 PM
okay i grounded it to the motor and it did spike to hot. what does that mean?
Old Dec 1, 2010 | 02:26 PM
Replace the temp sender unit.
Old Dec 1, 2010 | 02:40 PM
thats just the plug in the head under the distributor right?
Old Dec 1, 2010 | 02:44 PM
Replace what the connector was plugged into. Yes, the sending unit screws into the block under the distributor.
Old Dec 1, 2010 | 10:12 PM
harms_is_back's Avatar
man thats some crazy **** lol need to try that just for ***** and giggles lol
Old Dec 3, 2010 | 06:35 AM
thanks that fixed the problem. i guess the one i replaced it with before was bad also
Dhunt678
Nov 1, 2012 09:09 AM
mikestang89
14
Apr 28, 2011 03:51 AM
xx7xx
Sep 26, 2008 07:59 AM
o'malley_808
Jul 12, 2005 06:02 PM
Del Souless
Sep 4, 2004 02:26 PM
