Honda Parts, brackets, mounts, harness, ETC.. CHEAP!!
Tons of Honda Parts.
Misc engine and underdash Harnesses - Obd 0, Obd 1, Obd 2 (most cut but still salvagable) $25 each
GSR Ac Brackets - $20
Single Cam AC Brackets - $20
B series Alternator Brackets - $20
H Series Alternator bracket - $20
H Series Alternator - $30
H Series OEM Fuel Rail - $25
H Series Rear Water Tube - $10
H series Post mount - $20
B Series Post Mounts - $20
Power Steering pumps - B series , Single cam - $20
Shift Linkage - Single cam - $30
B series Test pipe (OEM) with O2 Bung - $60
OEM GSR header with heat shield no scratches or dents- 40$
Single Cam OEM fuel Rails - $15
Two Stock B Series (Hydro clutches with Pressure plate) - $20 each
Misc engine mounts (stock, Swap mounts,)
Complete set of H22 EK mounts - $150
92-95 civic Shock Fork - $10 Each
88-91 Civic Shock Fork - $10 Each
Tons of other Honda Parts Txt or Call for questions.
(626)374-7443
(626)374-7443
TAKE IT ALL FOR $200
Power steering pumps, Main girdles, Wiring harness, Mount Kits, Brackets, Post Mounts, Ac Fans, Ac Compressors, head bolts, Main bolts, Mains for LS, Mains for H22, Stock B series clutches,
LOTS of stuff.. i have about 6 tubs of stuff.. Take it all for $200!!
