crx compressor or water pump? help needed fast
The AC compressor is on the front *driver* side of the engine. Water pump is driven by the timing belt - your car would not run if this belt broke.
They're both on the same side, but the waterpump is driven by the timing belt and is under the timing belt cover. The alternator has it's own belt, as does the AC. The AC compressor is in the front near the radiator, so That should be the one you want.
Slow typing
Slow typing
It's pretty straight forward. I'm guessing your difficulty stems from the fact you may be missing the tensioner pulley. It happened to someone else also, it should look like this:
EGcivicBoy
Nov 11, 2003 05:21 PM
