B16 stalls and is difficult to restart! ANY IDEAS!
Old Nov 30, 2010 | 06:36 AM
kc_kc's Avatar
Icon2 B16 stalls and is difficult to restart! ANY IDEAS!
Hey i got a b16 that wont start up. it got fuel coming and spark but dont know whats wrong. want i changs spark plug, wire, fuel pump, fuel reglater , fuel pressure. has msd kit. swap my cuz distributor to it but wont start. any idea out there that might help.
Old Nov 30, 2010 | 06:43 AM
NaveLB's Avatar
Default Re: NEED HELP TO START UP A B16! ANY IDEAS!
Sounds like a ground or you could of switched up a plug or something. i could be wrong but thats what I would check first. Check to make sure your grounds are hooked up
Old Nov 30, 2010 | 07:09 AM
kc_kc's Avatar
oh thanks i check it out too but also i forgot that when the car runing, it some time dien while the car in gear. so will that cause anything?
Old Nov 30, 2010 | 07:10 AM
BorriquaJoKer's Avatar
Do u have compresion I means witha Gage not by ear n wat is it
Old Nov 30, 2010 | 07:12 AM
Former User's Avatar
Is this a stalling rather than no-start problem?
Old Nov 30, 2010 | 09:18 AM
kc_kc's Avatar
nope y should i get one?
Old Nov 30, 2010 | 09:19 AM
kc_kc's Avatar
yea its just stalling and crank
Old Nov 30, 2010 | 09:21 AM
4stagecandy's Avatar
probably firing order is wrong
Old Nov 30, 2010 | 09:25 AM
kc_kc's Avatar
we check that and the belt. but the car was running tile it just die.
Old Nov 30, 2010 | 09:37 AM
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
When the engine won't start
, have you checked for spark at the plugs and listened for whether the fuel pump primes? Is spark bright white? Any CEL codes?
Old Nov 30, 2010 | 02:12 PM
kc_kc's Avatar
Default Re: B16 stalls and is difficult to restart! ANY IDEAS!
yea their is spark white yellow. test at the spark wire. will b18 wire fit too. got to try that if its work or not.
Old Nov 30, 2010 | 02:22 PM
Is this when the engine won't start. And there should be no yellowish color, just bright white with a difficult to see tinge of blue.
Does the fuel pump prime?
Old Nov 30, 2010 | 02:31 PM
kc_kc's Avatar
yes... the car was runing and i just die suddenly.
Old Nov 30, 2010 | 02:37 PM
Yellowish spark could mean a blown coil.
Old Nov 30, 2010 | 02:46 PM
kc_kc's Avatar
kool i get that tomorrow and see what happen then thanks but fell free to put any news ideas in thanks.
Old Nov 30, 2010 | 03:01 PM
Resistance test the coil before replacing it.
Old Dec 3, 2010 | 06:02 AM
kc_kc's Avatar
oh thanks it up now. thanks
Eric724
Apr 28, 2011 06:23 PM
EF8IGHT
10
Nov 17, 2005 03:41 PM
temp
15
Jul 6, 2004 08:07 PM
4ghatch
May 22, 2004 10:50 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
