ls swap wont start...
So as stated above I have a eg with a ls and I'm having issues with it.
about last week car wouldn't start. well tryin to start it the fuel pump wouldn't prime so i checked fuses and nothing was blown so i got a new pump still wouldn't start. Then out of the blue it started. I found that when the car is cold i have to leave the the key in the RUN position then the fuel pump will kick on. So the car will then run fine but tonight it started to stall and the pump would not run, and while running it would shutter when i tryed to accelerate unless i backed of to barely any throttle.
Any ideas would be great thanks
Try resoldering the main relay, and also clean and tighten the ground on the thermostat housing.
NOUNOURS-EP3-2002
May 14, 2008 03:56 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
