Warming up tires
Warming up tires. I've been told and read many, MANY different things. The most ridiculous sounding to me was to "run it up to 70mph in first gear and rear brake while turning the bike slightly side to side", or "run up to 50mph and brake, up again to 50mph and brake. Once you get a good feel for your bike, you'll know that the tires are warm." I've been told by multiple people that swaying back and forth like you see nascar/f1 cars doing is not the way to warm up the tires, but this seems like the most obvious way to me. Are the physics that much different for two wheels? Some say that just riding is the best way which doesn't really answer my question to them about the fastest way to fully warm up a tire.
I would be curious anyway, but my main reason in asking is that there is a really tight turn that I like leaning into when going to work. If I've been riding for an hour or so and head that way, I lean hard. I would like to be able to do that everyday coming to and from work, but it only takes 5 minutes to get to that point. I'd hate to lay it down during my daily commute because the tire didn't grip as well as it should.
So, what ways do you use that you KNOW work? And a reason behind the madness would be appreciated.
honestly theres no way to completely warm up a tire in five minutes on the street, if you were on a track id say it was possible. the best thing to do is just sway side to side and gradually get further and further over on the tire. keep swaying til you get a few hundred feet from the curve. if its extremely cold out dont push it because no matter how warm you get the tire, if the ground is too cold you'll slip either way. dont use the rear brake when swaying and watch for leaves.
Unlike a car, bikes turn by leaning on a vertical plane, not by actually rotating the wheels in either direction on a flat, horizontal plane, so you end up getting very little radial load (Flex) on the carcass of the tire when swerving on a bike, thus generating very little internal friction to the tire carcass itself and thus little to no heat. However, accelerating hard and braking hard in a straight line puts substantial radial load on the tire carcass, forcing it to flex and generate a fairly substantial amount of internal friction and thus heat.
Also keep in mind that street tires are different than racing tires/slicks, they require substantially less heat to operate properly, and heat up much faster. Exactly how long it takes to reach a good operating temp on street tires varies based on a lot of factors, like the bike itself, the brand/type of tire, ambient temps, and of course, tire pressure, but as a ballpark figure, presuming your tires are at manufacturer spec on a sunny 70 degree relaxed commute I'd safe side it on 10 minutes. If you feel like Joe Rocket that morning I'd say less than 5 minutes if your riding heavily spirited from stop light to stop light.
Cliffs:
Swerving doesn't do **** to warm up tires
Accelerate/Brake hard to warm up tires faster
Don't sweat warm up times on street tires unless your local twisty spot/mountain/canyon is located right around the block from you or you feel like doing your best Rossi impression on a 30℉ day, once you reach the fun bits, you're good to go 95% of the time.
Make sure your tire pressures are at the correct PSI!
You can always tell the jackasses at the start of the track day, they're the ones swerving like morons on their warm up laps thinking it does anything at all for their tire temps.
Cliffs:
Cliffs:
Most of that sounds pretty reasonable. Nobody has had a reason why they do the accelerate/brake quickly, so I just thought it was stupid.
So why doesn't swerving do anything? The tire is using friction, maybe not much but some, to keep the bike from slipping, so why does that not heat the tire up? Or does it just take forever to properly warm up a tire that way?
Keep asking questions, the only stupid questions are the ones not asked that find you picking up the bike. Ride safe, and ride sane on the streets.
Originally Posted by RoadracingMag
Weaving
Makes For
Good Collisions
By Dave Swarts
Weaving to warm tires is a fiction that just won't die. All sorts of riders who should know better can be seen weaving wildly on warm-up laps, and we've seen plenty of collisions and near-misses caused by one guy weaving into another guy on a warm-up lap. Yet some riders persist in the belief that weaving actually does something other than create a hazard. So, since we had gathered a test bike, a test rider, all sorts of measuring instruments, some extra tires, and had a track to ourselves for our big tire test (Roadracing World, January, 2000), we decided to test the effects of weaving on motorcycle tire temperatures.
We conducted this experiment using Mark Junge and his 1999 Kawasaki ZX-6R, at Oak Hill Raceway. Michelin tires were used for this test, the front a standard Pilot Race, and a Pilot Race "W" on the rear. First, we measured the cold tires' core temperature in the middle and on both sides of the tread, front and rear. We then sent Junge onto the track to ride slowly in a straight line and then measured the tire temperatures. Then we instructed Junge to weave aggressively from turn eight to turn two and back again (approximately one-half mile), and measured the tire temperatures again to see how much heat was produced in the tires.
Next, we let the Michelins cool off. We then heated the tires on warmers for 45 minutes per Michelin's recommendation and took the tire temperatures. Then Junge went out and did the same weaving and temperatures were taken again to see if additional heat was built up or if heat was lost.
Next, Junge was sent on a standard warm-up lap. We then quickly measured the tire temperatures. Then Junge did another 1.8-mile warm-up lap, this time weaving, and we measured the temperatures again to see if weaving built additional heat when compared to a standard warm-up lap, kept the heat in, or lost the heat. Then we did the half-mile of weaving again before taking the tire temperatures yet another time.
To complete our test of tires and temperatures, we sent our rider out on two normal warm-up laps. Once back on the starting grid, we stopped the bike with the tires remaining on the pavement just as you would sit on a grid with the 3-minute board in the air. Then we measured each tire, as quickly as possible, to see how quickly the tires lost the heat built up on the warm-up lap.
The first thing that we discovered while trying to take the temperature of the cold tires was that the sun has a significant effect on a tire's temperature. Our test bike was under a canopy but the front tire was still in direct sunlight on an 88-degree, Texas afternoon. Just from sitting in the sun, the front tire had between 10 to 20 degrees more heat at the tread's core, not the surface.
When Junge rode in a straight line at line at approximately 40 mph for about a half-mile, the shoulder of the tire that was in the shade remained at 85-88 degrees F. The temperature at the center of the tires went up slightly while the shoulder of the tire facing the sun also started picking up heat. Then our rider went on his weaving course and came back. Once again the side of the tire facing away from the sun and the center changed very little. The side of the tire facing the sun continued to gain heat. We attributed this solely to the sun as Junge was careful to weave equally hard on each side of the tires.
Junge went back to his task of learning Oak Hill on his "A-bike" while we took the weaving test bike back under the canopy and applied Tyr Sox tire warmers for 45 minutes. After the warmers, the rear tire had about 129 degrees F across its entire tread while the front held 171 degrees F on the right, 175 degrees F on the left, and 182.4 degrees F in the center. Both warmers were on for the equal amounts of time.
Just as I was organizing a theory into how the tire warmers have equal heating elements but the (120) front tire has less surface than the (180) rear tire, I noticed that the bike had been put back in its original parking spot with the front wheel in the sun. Although I can't rule out my equal tire warmers versus different-sized tires theory, I can't rule out that the strong sunlight increased the effect of the warmers.
As soon as we took the post-warmer temperatures, Junge went out to do the same exact weaving course. The right/away-from-the-sun side of the rear tire lost 12 degrees of heat. The right side of the front lost 45 degrees. The center of the rear lost 5 degrees of heat. The center of the front lost 43 degrees. The left side of the rear tire that was facing the sun stayed steady at 129 degrees while the left front only lost 36 degrees. Once again weaving did not build or hold the temperature. The sun had more effect than weaving.
As soon as these temperatures were taken, Junge was sent off to do a normal hot lap on the twisty, 1.8-mile course. After the hot lap, the heat in the rear remained fairly constant, cooling just a few degrees. The front continued to steadily lose its significant tire warmer heat. However, the left sides of the tires were the warmest parts. We could not attribute this to the sun because throughout our two-day test, tires always recorded higher temperatures on their left sides after doing any laps at speed on the track.
Then, we sent Junge to do an entire lap of weaving. Again, the weaving failed to hold heat anywhere on the tire. Then Junge once again did his straight weaving test, and the tires began cooling rapidly. In fact, during weaving the tires lost heat as rapidly or more rapidly as just standing still.
For our final test, we sent Junge out to do two laps to get some heat in the tires. Then as the bike stood still on the racing surface just as it would on a grid, we measured how quickly the tires lost their heat. I had originally hoped to measure the six spots on the tires every 10-15 seconds. That proved too ambitious. I ended up measuring each spot every 45-60 seconds. Next time, I'll have two pyrometers. This was very interesting, though. While the center and right sides of the tires lost 10-12 degrees over a 4-minute time period, the left side of the rear lost very little heat and the front gained heat from the direct sunlight.
Here are some conclusions. Tire warmers will produce the highest pre-race tire temperatures. During the tire comparison test consisting of 8-10 laps at 100 percent speed, we sometimes did not record temperatures higher then straight off the warmers. So the best way to warm tires is to use tire warmers.
The second-best way to warm tires is to take a hot lap. As powerful as the sun proved to be, a good hot lap produced more heat than time in the strong sun, and it's quicker, too.
The third-best way to warm tires is to leave the tires in strong, direct sunlight. Just don't forget to get both sides.
But weaving, no matter how aggressive your lean angle and your speed or how long the distance covered, does not build any additional heat in a tire!
So now, we will hopefully never see another unfortunate accident from useless weaving on a starting grid or pit lane. Case closed.
Makes For
Good Collisions
By Dave Swarts
Kiwi answered that in his post: Unlike a car, bikes turn by leaning on a vertical plane, not by actually rotating the wheels in either direction on a flat, horizontal plane, so you end up getting very little radial load (Flex) on the carcass of the tire when swerving on a bike, thus generating very little internal friction to the tire carcass itself and thus little to no heat. However, accelerating hard and braking hard in a straight line puts substantial radial load on the tire carcass, forcing it to flex and generate a fairly substantial amount of internal friction and thus heat.
But, I'm obviously no expert. I'll take their word for it. If I had the instrumentation and a track, you better believe I'd check it out myself.
Thanks for the feedback, guys. And thanks a lot for the article, kiwi. It's always reassuring to see some test to back up what somebody says. I can't stand those that swear by something even though they don't know why they believe it.
beat ignition
May 24, 2015 12:56 PM
