97 Civic LX - What engine swap should I do?
Old Nov 28, 2010 | 10:28 PM
artm26's Avatar
Default 97 Civic LX - What engine swap should I do?
I have a 97 honda civic lx with a base 1.5 engine and i want to do a swap and put a vtec i like speed but i am not sure what engine to get can someone help me
Old Nov 28, 2010 | 10:41 PM
mattyfo0z's Avatar
Default Re: what engine should i use
Search. Research. Search some more.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
Old Nov 28, 2010 | 10:52 PM
92bseries's Avatar
Old Nov 29, 2010 | 05:15 AM
tangkianwee's Avatar
B18C
Old Nov 29, 2010 | 05:16 AM
B18C should be good..!
Old Nov 29, 2010 | 06:15 AM
eGxHatchx's Avatar
h22a4! i have a complete swap for you pm me if your interested
Old Nov 29, 2010 | 06:44 AM
foo fighters's Avatar
are you sure it doesn't have a d16y7 ?? it should,if so get a d16y8 head and ecu/ecm and everything else you need CAN be found on this site. in any case their right, research.
Old Nov 29, 2010 | 07:13 AM
12three's Avatar
go k-series..
Old Nov 29, 2010 | 07:52 AM
george323's Avatar
if you like to high rev, go with a b-series. Cheap, and if you built it right. Youll be spanking k-series all day and night
Old Nov 30, 2010 | 01:33 AM
artm26's Avatar
thanks all
Old Nov 30, 2010 | 01:45 AM
NOFX's Avatar
H-T White Ops
A lot of factors come into play when coming up with the engine you'd like to use for your car.
- What sort of performance are you looking for?
- What is your budget?
- Do you care if it's legal? If so, check to see if local laws might count out some swaps (such as CRV engines are considered light truck engines and not allowed to be swapped into passenger cars in some areas).
- Do you want boost with this swap?
- What skill level are you looking for for the swap itself (wiring, etc.)?
Look at the positive and negative points of each swap.
A V6 sleeper might sound like a great idea... until you figure out that J-series isn't fitting in there without a giant hole cut in the hood. Sleeper status negated... at least a little.
An ITR engine might sound perfect... until you look at the price tag.
A K-series might sound neat. You'd be a bit different from those B and D-series swaps. But all those custom parts start adding up.
The tried and true B, D and H-series swaps are, well, tried and true. But maybe you want something a little different and you can afford it financially and you can afford the downtime.
For some, picking out the right engine might be as much as, "I like this engine, but want VTEC." If so, then you might be happy with a D16Z6 or D16Y8. Others might be happy as long as they have a DOHC in there. An easily found inexpensive LS could be their answer.
Good luck with you decision. And remember that you don't need to buy the first engine you find! If it sounds too good to be true, it probably is. And read up on any company before you buy from them!
Old Nov 30, 2010 | 02:48 AM
JasonYo's Avatar
Yeah you gotta narrow it down a bit.
Whats your budget? are you doing it yourself? if so how much experience do you have? What resources do you have?
Then it should be pretty easy to figure out what you want.
If unlimited budget and resources, then a jdm k20 itr swap is very nice.
Old Nov 30, 2010 | 06:46 AM
NaveLB's Avatar
turbo your motor.
Sherlia
22
Feb 27, 2013 12:03 PM
99380066
Feb 18, 2013 08:59 AM
ja79
May 5, 2011 06:02 AM
rcmf5525
Acura TL, RL & ZDX
Dec 21, 2004 07:15 PM
