jdm gsr swap misfire @ low rpm's
As stated I'am having a problem with motor breaking up at low rpms, At first i thought it was a fuel issue so i swaped out the injectors, fuel filter and pump. None of that solved the problem so i went ahead and swaped out the distribitor,spark plugs and wires....again none of that helped....checked all grounds and even added a few grounds to the motor...still having the same issue...and now i'am stuck, the bad part about the whole situation is, the previous Ls motor that was in the car suffered from the same issue, hence the reason why I went to jdm engine depot and got the gsr, I know its impossible for this motor to be suffering from the same problem as the Ls motor did.....I dont know what else to do....any help or advice would be greatly appreciated, Thanks in advance....
P12 EG6
Oct 27, 2008 03:50 PM
