Fuel system
The only reason you would need to upgrade your fuel system is if your engine is requiring more fuel then your fuel system can supply. The stock fuel lines can handle around 500-600 whp on c16 fuel using a single walbro 255 lph fuel pump and 1000cc injectors.
The capacity of the fuel pump and the Fuel Pressure Regulator will control the pressure at the fuel injectors. Larger fuel line would not make the Fuel Pressure Regulator maintain any different pressure, niether will it increase the capacity of the fuel pump.
Enjoy..
Enjoy..
Dominic-CTR
Oct 24, 2004 04:08 AM
Bantam
Mar 7, 2003 08:58 AM
