Bogging below 3k, tried everything!
Old Nov 28, 2010 | 04:12 AM
porkchop's Avatar
Default Bogging below 3k, tried everything!
Hey everybody, I'm back to Honda-tech, this time with a daily commuter CRX!
stock 91 CRX DX, DPFI 1.5l
TPS reads .7 to 4.1 and very smooth with no jumps. I think it's close enough.
I pulled every sensor and plug one at a time, pulling the ECU fuse afterwards for a few seconds to clear memory.
The only thing I've found to actually clear up the problem is pulling the bottom green fuel injector clip. Then, it pulls hard and solid all the way to 4k where I'm either hitting either the limp mode limit from CEL or just running out of fuel since injector is unplugged. (16 blinks, fuel injector, duh)
No CELS or blinking ECU otherwise, I've tried cleaning the injector and even soaked in diesel overnight, still no good. Should I just replace it or have it cleaned?
Thanks,
Alberto
Old Nov 28, 2010 | 04:45 AM
Foowee's Avatar
Default Re: Bogging below 3k, tried everything!
Dpfi injectors are all over the junkyard. You could tool bag 5-10 the next time you get something large. I'm sure there would be a good one in the batch.
Have you checked your cam timing? You may want to try advancing it a tooth... n don't for get to adjust your dizzy whenever you make a cam adjustment.
Old Nov 28, 2010 | 05:15 AM
porkchop's Avatar
It runs so good at mid to high RPM, to me it feels like a an EGR valve sticking open like in my old 'lude. But yes, I should go ahead and check the timing later. I know about walking the yard and picking up a few, I'm just working the exact hours the local yard is open. d'oh.
Old Nov 28, 2010 | 05:57 AM
95 iteg's Avatar
i have a 95 teg and everyonce in a while it will bog out from like 2k to about 3k but when i stomp the gas it will come out of it. it will do this for a min or 2 then not do it for along while. i have no idea what it could be
Old Nov 28, 2010 | 02:56 PM
porkchop's Avatar
Hey Foowee, you were onto something!
Hooked up the timing light, jumped the plug under the dash, couldn't see any marks on pulley. Had to get under the car and rotate crank, riding the edge of pulley with my fingernail till I found the marks. TDC (mark by itself) and then the 3 lines close together. Marked the center one of those with white appliance paint and hit it again with the light. The mark was about 1.5 inches towards the firewall, pulled the distributor towards the radiator max (retard) and shrank that gap to about half an inch.
I used this picture from another thread to understand the marks.
http://img233.imageshack.us/f/912358sg7.jpg/
So skipped a tooth on the belt and most likely culprit of my bogging before < 3k after warm up. Am I understanding this correctly? Can I just set the belt timing back where it belongs and tighten with adjuster? Or is that half the job and might as well replace it? Tell me what I don't wanna hear, it's alright.
Thanks!
Vtec04
Sep 28, 2017 05:05 PM
branboom
Jan 29, 2016 07:25 AM
be18see1
Jan 16, 2008 02:47 PM
redcardude
Jan 4, 2006 05:51 PM
EFz6er
Apr 1, 2005 02:11 PM
