97 Civic, weird noise on starting up! Video inside
Old Nov 28, 2010 | 12:15 AM
cr2250's Avatar
Default 97 Civic, weird noise on starting up! Video inside
The weather is starting to drop below freezing now. My car has also decided to produce this noise. I can't really describe it so I took a video. The noise is really noticeable around 17 seconds. Definitely haven't heard this before. My oil level is fine. Should I bring it to my mechanic next week? I drive my car a lot and would hate to see it blow up if I used it knowing I could've prevented it.
The sound eventually goes away, maybe after 15 minutes of driving. But I can notice it with the acceleration on the car and at Idle. Doesn't sound pleasant to the ear at all, but then again may be normal for the engine due to the cold?
Thanks
Heres the video
http://www.youtube.com/watch?v=S29hy7A_HAY
Old Nov 28, 2010 | 08:16 AM
Former User's Avatar
Default Re: 97 Civic, weird noise on starting up! Video inside
Try to pinpoint the noise. Is it coming from the drive belt area (e.g., alternator or belt)? An inexpensive engine stethoscope may help.
Old Nov 28, 2010 | 08:27 AM
itsmejto's Avatar
A 2 ft. piece of rubber or plastic hose in your ear will suffice for pinpointing the noise.
Sounds like it may be a bearing on it's way out, alternator/belt tensioner / A-C compressor etc.
Old Dec 20, 2010 | 11:50 PM
Bad Brian's Avatar
From: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
I was wondering how to describe my noise!
did you find an answer yet? my 98 Civic EX has started doing it primarily when cold. sometimes the noise switches to a loud whistle. sometimes it is not there at all. I have 86K and ALL belts were done last year about 2k ago at the Honda dealer.
Old Dec 21, 2010 | 05:00 AM
grumblemarc's Avatar
The Grumpiest
"Sounds like it may be a bearing on it's way out, alternator/belt tensioner / A-C compressor etc."
My car is making that sound. Just haven't gotten around to changing out the parts. It's not the belts.
pliskin8
Apr 22, 2012 02:22 PM
bpetruzzo
24
Jul 30, 2011 03:47 AM
5thGeneration
Nov 11, 2007 08:46 PM
JDMF22B
Jul 13, 2005 09:16 AM
frosted
Jul 2, 2005 06:36 AM
