H swap electrical problem - main relay clicks without key in ignition
got my h swap finally runnnng, well I did. I was getting a code 22 vtec pressure switch, so I swap the wires on the switch. tried to start back up then blew the back up fuse. I swap the fuses and wires back. now when I connect the neg terminal, the main relay clicks continuosly. mind u the ignition is not on. I also routed some vacuum lines as the the same as my brothers car, same motor and car. check grounds and all are good. what could this be?
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
and...
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
and...
it sounds like you've got a short somewhere and your by passing the key ignition circuit. check your wiring, if your posi leg is shorted to the frame then you will get a circuit as soon as you connect the negy. looks like your going to have to get some wiring diagrams out and test terminals for correct polarity
ronj@ht...lol, yea sorry bout that. finally had the beast started so i was rushing to get her right. you know how it is, one problem after another. but as long as I know you're here to correct me, I'm good.
I will check the pos term and see what's grounding
94 civic ex with h22a1/f22 trans w/lsd. balance/blueprinted bottom, mahle gold flat top pistons, eagle rods, polished crank, honed and resurfaced walls, full sk2 internals, pnp runners, obx fuel rail and regulator, precision 770cc injectors, obd1 jam internal dizzy. running n/a for break in, then switchng to -7cc mahle pistons for turbo.
nope..using stock harness, just extended wires. when I start it, it putts and there is a small squeal from the dizzy I think, cane pin point it. if no gas, it dies. moving so I have no computer and I threw out my manual printout. the wire color for the iacv is blu/ylw right?
Yes sir Blue and Yellow/Black I had the same problem and I had the dizzy wires all screwed up and the engine would start but i would have to keep giving it throttle to keep it running. I would recheck your dizzy wires because your ignition signial wires go to the dizzy also. if you get one wire wrong it can cause all sorts of problems for ya.
jhota
Sep 14, 2006 05:03 PM
