98 EK misfiring
Old Nov 27, 2010 | 04:06 PM
civic*chick98's Avatar
Icon6 98 EK misfiring
Ok, so my car has been misfiring random cylinders. First it was 2 and 4, then 1 and 3, now it is only cylinder #4. I put new NGK spark plugs, good spark plug wires, and replaced the cap and rotor. It has been throwing these codes on and off for the past month. The engine is a D16Y7 Auto.
I went to start my car tonight and the check engine light was flashing (which never happened before) and was idling horribly. Also car has a slight rod knock but it sounded worse.
Any suggestions on what parts to look into that could cause these problems? If I can't find a solution, if you know of any places near NJ/ PA that has good swaps for a reasonable amount, that'd be appreciated.
Old Nov 27, 2010 | 08:11 PM
Former User's Avatar
Default Re: 98 EK misfiring
Test the coil and have the ICM tested by an auto parts store.
Old Nov 28, 2010 | 02:57 AM
Okay, I will try that. Thanks.
Old Nov 28, 2010 | 02:16 PM
update: exhaust manifold is severely cracked and possible that the cat is clogged. Would this cause a misfire as described?
JeremyG
Honda CR-V & Element
Jul 2, 2014 07:25 PM
ek95
Dec 13, 2012 06:30 AM
Tong.Y
Nov 5, 2009 02:25 PM
JDMtegg19
Sep 25, 2009 07:37 AM
sickofitall1113
Jul 31, 2007 12:47 PM
