J32 Swap Into 2001 Accord V6
Hi everyone. A friend of mine has a J32 of a 1999 TL that he's willing to give me for free so i thought why not just get rid of my J30 and swap the J32. Do i need anything besides what i already have? can i use my stock ECU, wire harness, mounts? The car is automatic but its gona stay automatic. Let me know, looking to do this swap soon.
personally, I wouldn't do it. J32A1 - 220HP. lil bit of a gain.
It should be compatible with your 4-speed and bolt right up. J30A1 ECU could run the J32A1, maybe not at 100% because the maps would be different.
I don't know if the ECU connectors are the same for both engines though. Same for the engine sensors. You may have to use a J32A1 engine harness.
I would compare the ECU plugs and harness connectors for both engines to see if you would need a J32A1 ECU.
How would i go about to get rid of my cel codes due to the j32 swap into my av6. If i got a 03 cl type-s ecu would that get rid of the cel codes? Any suggestions would be appreciated.
