bottom end gasket question
Who the fack changed my title?!
im going to be running the gsr oil pan as well as the oil pickup tube from a gsr on my ls block. besides the oil pan gasket, rear main seal, water pump gasket, oil pump gasket, what other gaskets should i get? this is from head gasket down. does the oil pickup even require a gasket when mating to the block,oil pump?
