cel p0441 evap emission incorrect, purge flow on 96 gsr
Everything on the black canister is hooked up. But what I noticed is there one vaccum hose on the bottom of the intake manifold that is capped off and also if your looking down at the oil filter to the left. There is a black box with a red nipple on it that looks like it should have a vaccum line hooked up to it. My question is would it throw that code with the things I mentioned? I already tightened the gas cap and also replaced the gas cap. So I need some advice. I will post some pics to tell u guys what you think. Any advice would help. Thanks
This pic is where the black box I am talking about with the red nipple that a vaccum line should be hooked up.
The other pic is where one of the vaccum lines on the bottom of the intake manifold is capped off by a small bolt.
Anyone got advice on this problem. I have did a search on it but nothing. Anyone have any input on this problem?
http://www.ff-squad.com/tech/howto/sk2manifold/
Check out the section on Pcv valve, one hose goes to the block fitting to the black box. The other hose goes from the black box w/pcv valve to the intake manifold connection
AudioFunk
Apr 9, 2015 07:40 AM
blacktibby07
May 27, 2011 06:23 PM
