P72 chip in P28?????HELP ME!!!!!!!!!!!! (GSR SWAP)
Old Nov 26, 2010 | 07:11 PM
Gofastturnleft's Avatar
Default P72 chip in P28?????HELP ME!!!!!!!!!!!! (GSR SWAP)
Ok Im a Noob when it comes to computer. I am doing a GSR swap into my civic and have a P72 with a fried mother board. I also have a chipped P28 from my old single overhead turbo set up. Can i Take the chip with the base GSR base map from the P72 and put it in the P28 or is there further programming needed???????????
Old Nov 26, 2010 | 07:16 PM
mtber's Avatar
Default Re: P72 chip in P28?????HELP ME!!!!!!!!!!!! (GSR SWAP)
You may install a 28 pin eprom chip into your p28 with a tune for your gsr engine.
The only disadvantage is that the p28 ecu can't control the stock intake air butterflies you will simply need to keep them open all of the time or upgrade to a skunk2 style intake manifold.
Check out: http://www.phearable.net/shoppingcar...emap-p-60.html
Let me know if you have any other questions.
Old Nov 27, 2010 | 05:40 AM
sweet. i already got one on. now what will cause an ecu to fry???????
Old Nov 27, 2010 | 05:48 AM
HAMOTORSPORTS's Avatar
Many things can cause this. The number one problem we see is people switching the intake air temp and idle air control valve plugs. This fries the board at Q31
Old Nov 27, 2010 | 06:22 AM
Wow i didnt know that could do it. I thought it would have to a wiring problem or something. Well here is some pics. The guy said it was the rev limiter but idk. So see what you think it might be.
Old Nov 28, 2010 | 05:00 AM
any ideas what this bun mark is?????
Old Nov 28, 2010 | 07:21 AM
mtber's Avatar
Your answer is above...
93bubble87
Engine Management and Tuning
11
Jan 5, 2010 07:59 PM
eg6206
10
Apr 20, 2009 01:47 PM
mikeledez_ho!
22
Oct 22, 2008 11:45 PM
maxheat
10
Feb 9, 2005 12:55 PM
streetlights
Mar 19, 2003 10:41 PM
