No clutch? Not working
Old Nov 26, 2010 | 06:18 PM
jlowellintegra's Avatar
Default No clutch? Not working
Today out of no where my clutch went out the pedal has no resistance it won't go in or out of gear so I checkedy fluid it was empty...would fluid do this because my clutch is brand-new exedy pls reply
Old Nov 26, 2010 | 06:24 PM
CJR inc.'s Avatar
Default Re: No clutch? Not working
ya this happen to me few months bac,itt was my clutch release cylinder.also check for lose hoses
Old Nov 26, 2010 | 06:52 PM
How did you fix it????
Old Nov 26, 2010 | 07:58 PM
vtaker's Avatar
you need to re-bleed the whole system. check the team integra article.
also, check around your pedal to see if there's a leak.
Old Nov 26, 2010 | 09:06 PM
cheapskate's Avatar
Could be your clutch master cylinder. look up under the dash and see if there is any fluid that has run down the firewall. If your master cylinder was empty you has a leak or a bad component somewhere in the clutch hydraulic system, check out all components and connections.
Old Nov 26, 2010 | 09:45 PM
aemintgsr's Avatar
Most likely is a leak, not your clutch...i bet money its on the clutch master cylinder, check under the clutch pedal like stated before....if not it might be leaking in the slave cylinder. Check and let us know
Old Nov 27, 2010 | 10:09 AM
Ok today I went and bought brake/clutch fluid dot 3 and filled her up and so far so good its smoother than it was before no jumping at all can't believe I let it go empty, I did check by the firewall for leaks didn't see anything although I found out I'm leaking oil which pisses me off the motor was put in a month ago
Old Nov 27, 2010 | 08:15 PM
meyerk9's Avatar
That's why you drive a cable clutch
Gomdohree
Apr 24, 2008 06:20 AM
Lb1atx
Sep 7, 2007 05:16 AM
Dsee2
Oct 23, 2005 10:10 PM
Fullthrottlegsr
Jun 22, 2005 01:21 PM
johknee
Dec 8, 2004 06:24 PM
