Transmission & Drivetrain Gearboxes, Differentials, Clutches
Winter Trans Oil recommendation
Old Nov 26, 2010 | 06:52 AM
unusual71's Avatar
Default Winter Trans Oil recommendation
So i just got my '95 integra LS back on the road.
This car only sees 0 to -40*C temps I was wondering if there is a trans oil that does good in the cold, or if i should just stick with honda factory trans oil, since the stuff is pretty thin anyways. obviously the trans will warm up as I drive but I never drive it hard.
Once warmed up, I noticed that when shifting slow there is a slight "chunk" but if i go quick its pretty smooth, and I honestly never take the car past 3k rpm however when i was testing it out last year I noticed it does have a slight grind going into 3rd at high rpm, is this going to become more of a problem at the lower rpms if I go to a thinner oil? im usually shifting around 2400-2600.
Old Nov 26, 2010 | 07:08 AM
1991civiclx13's Avatar
Default Re: Winter Trans Oil recommendation
honda mtf, redline, royal purple... good idea to change it before the winter
Old Nov 27, 2010 | 06:39 AM
unusual71's Avatar
thanks for recommending the 3 types of oil that i would get recommend no matter where or what specifics i asked. really, big help, thanks
Old Nov 27, 2010 | 09:06 AM
95skunkedgsr's Avatar
..... so what did you want to hear??? you can put 10w30 in it i guess .. might be hard to shift when cold
Old Nov 27, 2010 | 09:27 AM
unusual71's Avatar
did you even read the first post?
I want someone who has experience specifically in the cold so that its NOT as hard to shift, because the trans is not mint. just trying to see if there is something i should avoid thats all.
arkomandos
Mar 31, 2011 05:18 AM
p1ccoloz
Aug 4, 2005 05:17 PM
BoBo Racing
Aug 12, 2003 10:35 AM
NorCalRacer1
Apr 30, 2003 01:31 PM
io_burn
Dec 30, 2002 05:01 PM
