vtec kicking at 6000RPM?help plz
Old Nov 26, 2010 | 12:31 AM
carlossolorzano's Avatar
Default vtec kicking at 6000RPM?help plz
i have a ls/vtec and my vtec used to kick in at 4500rmp's and like 3 days ago it started kicking in at 6000RPM's can anyone help me out.... is a obd2
Old Nov 26, 2010 | 12:53 AM
racebum's Avatar
Default Re: vtec kicking at 6000RPM?help plz
this thread has the makings of fail written all over it.
the vtec crossover point is hard set in the ecu.
since you have an lsv you should have a tuned custom ecu. ask your tuner where vtec was set and you'll have your answer.
Old Nov 26, 2010 | 09:54 AM
JdmTypeRdc2's Avatar
If you have a GSR head, you do realize that VTEC is set at 4400rpms. The butterflies then open up at 5800rpms. Maybe you have it confused??
VTEC cannot engage differently. Unless you have no oil/lack of oil, and the oil pressure goes down. This causes the ECU to go into safe mode, therefore, not allowing VTEC to occur at all
Old Nov 26, 2010 | 10:03 AM
nikesb4dub's Avatar
x2222222
p.s. check your oil level
mr2passat801
Nov 26, 2008 05:25 AM
msbhvn_DC2
Feb 9, 2006 07:39 AM
pbizzlegsr
Jun 30, 2004 03:14 PM
b19coupe
Sep 3, 2003 07:02 PM
vspec12
Nov 5, 2001 05:25 AM
