Need help on my chasebay harness
Old Nov 25, 2010 | 08:19 PM
Juan_95_Integra's Avatar
Default Need help on my chasebay harness
I was seeing if you guys can tell me where this 2 wires go to any help would be great
http://www.facebook.com/album....eater
Thanks!
Old Nov 25, 2010 | 11:10 PM
teamLegendz_sd's Avatar
Default Re: Need help on my chasebay harness
Looks like OBD2 for the injector plugs.. and that missing one might be for the noc sensor cause it would be close to the location of the alternator plugs it's inline with..
Old Nov 26, 2010 | 04:25 AM
Thanks man i'll try that. And you think i can just get obd2 injestors or is there other plugs in a obd2 that wont work on a obd1 motor???
Old Nov 26, 2010 | 04:47 AM
zccivicex's Avatar
the injector plugs and alt. plug look like obd2 to me
Old Nov 26, 2010 | 09:11 PM
you need obd2 injectors for those plugs to work. If your car is a obd1 and you already have obd1 injectors just de-pin the plugs and pin into obd1 plugs and you'll be fine.. either way it'll work fine,,,,,, but obd2 plugs are sweet cause you can squeeze and bamm the thing comes off easy obd1 is a pain in the *** due to you need a pick to take off..
Old Nov 27, 2010 | 03:15 PM
6Spd_EJ6's Avatar
The one with the pink wire is the knock sensor. Obd2 harness looks like.
Old Mar 20, 2011 | 10:22 AM
Thanks!
tougetuned_ef
Jun 14, 2011 05:24 PM
TwotoneC1Da9
Sep 28, 2010 07:38 AM
aarontrini85
Jun 5, 2007 01:15 PM
SargentNg
Aug 20, 2005 06:54 PM
aw1234dude
Sep 28, 2003 02:56 PM
