1992 Accord clock/radio issues
Old Nov 25, 2010 | 03:56 PM
404notfound's Avatar
Default 1992 Accord clock/radio issues
First of all I hope everyone enjoyed their Thanksgiving.
This problem just started a few days ago. The clock flickers and won't keep time and the cd player(aftermarket sony) also flickers on and off. I have checked the obvious and replaced both the radio/backup fuse and the fuse on the cd player itself. I've read of another member having a similar issue "NOFX"
I believe but I searched and didn't really find anything.
One thing I have done is remove the cd player and harness to see if it was in my wiring which made no difference.
Thank you
Old Nov 25, 2010 | 05:56 PM
My02accord's Avatar
Default Re: 1992 Accord clock/radio issues
Sounds like a loose power wire or ground, something that is on the same circuit as that clock anyway. Recheck all your wires, all you need is a loose ground or a butt connector someone didnt crimp good enough and that will happen.
Old Nov 26, 2010 | 11:39 AM
I just checked everything I know how to check and the problem is still there. I checked all the fuses and everything seems good. Now I've noticed that the clock is not resetting when off. This is hard for me to explain but for example say I set it at 2:00, as long as the key is on it will keep time. Say I take the key out at 2:04 and wait 10 minutes. When I put the key back in it will be at 2:04 or whatever time it was when I shut it off. The radio is not working at all now.
I found the main battery ground disconnected and I hooked it back up with no change.
I am really stumped here.
Old Nov 28, 2010 | 03:19 PM
Okay so I checked to see if I was getting proper voltage and I am. I checked the ground and that seemed good too. I bought another adapter harness and replaced it just to see if it made a difference and it didn't. I also put my pioneer cd player out of my other car just to see and it also won't work. It won't even power up. Is there anything I can do to make a radio work?
Old Apr 29, 2014 | 11:36 AM
Jelysc's Avatar
Hi, I know this post is a few years old and I don't know if you will ever see this but, I am currently having the same issue and was curious if you ever found out what might be wrong, and what you did to fix it. Thanks so much!
Xilade
Feb 10, 2005 07:29 PM
old-sk0ol
Jan 12, 2005 05:27 PM
xSCTYGx
Audio / Security / Video
May 31, 2004 08:44 AM
monhondatero
Jul 11, 2003 08:14 PM
