tachmeter question
Old Nov 25, 2010 | 03:43 PM
Wiretaju's Avatar
Default tachmeter question
i did a 5speed swap to my ef hatch and i didnt have a tach on. soo i bought a tach and installed it. my problem is that i know that im reving real high and it only read 3000rpm. whats the problem??
Old Nov 25, 2010 | 03:52 PM
Crx dude's Avatar
Default Re: tachmeter question
did you set the tach for 4 cyl? its a switch on the backside of the tach.
Old Nov 25, 2010 | 03:56 PM
hatchet_honda's Avatar
the tach should have a cyl. setting. really you coulda just found an si cluster and put that one in there. that is if it was the right year of course.
Old Nov 25, 2010 | 03:57 PM
Wiretaju's Avatar
yeah its one the 4cyl setting
Old Nov 25, 2010 | 04:01 PM
ok well what does the tach go up to? how high can you get it to read..if you floor it is 3k the highest itll move?
Old Nov 26, 2010 | 02:59 AM
Wiretaju's Avatar
about 3.5k - 4k rpm
Old Nov 26, 2010 | 06:28 AM
Crx dude's Avatar
where do you have the signal wire hooked up too?
Old Nov 26, 2010 | 02:07 PM
Wiretaju's Avatar
the blue wire the connects to the distributor
Old Nov 26, 2010 | 10:40 PM
behind the cluster?
Old Nov 30, 2010 | 11:10 PM
Wiretaju's Avatar
oh i swaped the 5spd cluster over the auto cluster, it just plug and play
Old Nov 30, 2010 | 11:31 PM
huh??
Old Dec 1, 2010 | 10:16 AM
240punk's Avatar
The Auto cluster has a tach, I was thinking about getting one and seeing if I could make it work. Is that what you mean you did?
streetrider002
Aug 8, 2011 11:57 AM
Fatcobra
Apr 17, 2007 05:20 AM
Vaans
11
Sep 2, 2004 12:22 PM
