How do i set up my suspention/tyers for drag racing
Old Nov 25, 2010 | 03:15 PM
x-s-i-v's Avatar
Default How do i set up my suspention/tyers for drag racing
hay guy need a bit of advice for suspention/tyer adjustment in my car
this is what i have.
honda integra da6 89-93 making 304kw atw 400hp atw
motor setup
b16a
dart sleeves 83mm
gt35/40 running 21 psi.
full boost at 4500rpm
gear box
ys1 gear box
mfractroy lsd
dss 3.9 drive shafts
GSR 1st 2nd
ITR 3rd 4th 5th
4.4 FD
traction bars
cusco super single
link plus ecu with launch control
car has full interior etc
tyer options i have are
toyo ra1 205-50-15
hooser 225-50-15
MT ET Streets 26" 10.5" 15"
the tyers i have to use are dot rated(rulls at merymery night wars for street cars)
suspention
D2 racing adjustables
frount camber kit
traction bars
strut bars
i want to know what tyers would best suit my setup
how do i adjust my sepention to get the best result
dampener, spring tention, camber, wheel choice, tyer presure
when i have the 26" slicks on the car sits high in the frount
MT ET STREET
HOOSERS
toyo ra1
400hp setup old tranny and stock axles, toyo ra1 tyers wet track
http://www.youtube.com/watch?v=Gr8V6Il90DU
200hp old tranny and stock axles toyo ra1 did better times
http://www.youtube.com/watch?v=rkJE9u7GKS0
im newish to drag racing havent produced any great times yet.
Old Nov 25, 2010 | 08:14 PM
jdmcivic2fast's Avatar
Default Re: How do i set up my suspention/tyers for drag racing
daaaayyyum! whos them 2 hotties in the 1st vid?? lol
Old Nov 25, 2010 | 08:39 PM
jnv255's Avatar
Drag racing on a cold, wet track... FTW
Old Nov 25, 2010 | 11:48 PM
team_ibR's Avatar
arnt those slicks a little too big for your setup?
Old Nov 26, 2010 | 10:22 PM
x-s-i-v's Avatar
my misses and her mate
Old Nov 27, 2010 | 09:18 AM
which one her mate? blonde hair or brunette?
Old Nov 27, 2010 | 09:26 AM
mangina's Avatar
tires.
Old Nov 28, 2010 | 01:24 PM
x-s-i-v's Avatar
blond
Old Nov 28, 2010 | 03:11 PM
95dxsir2's Avatar
i'd say go 24.5x8.5x13 slicks
maybe the 26's will work if the track prep is shitty all the time.
suspension-set it up as stiff as possible in the rear, and mid stiff on the front.
you can try adjusting the front at the track.
Old Nov 28, 2010 | 03:31 PM
x-s-i-v's Avatar
thanks mate
Old Nov 28, 2010 | 04:16 PM
racemycivic's Avatar
Id say De-Rice the car then worry about tires
Old Nov 28, 2010 | 06:32 PM
xsi-t's Avatar
imo car needs to be aligned to the tire and ride height and driver weight that you are gonna go down the track with. rear ride height should match the front it should be level or slightly higher depending on spring rate. then you will have to dial it in at the track.
here is what i started at then dialed it in
Old Nov 29, 2010 | 07:30 AM
B18c1turboedEK's Avatar
John Force burnout!!!!
ButtersH22
Jul 4, 2012 09:11 PM
dirtySOHC's
Aug 18, 2005 06:50 PM
fjt
May 11, 2005 08:29 AM
AllMotorITR
Dec 23, 2001 03:49 PM
