K swap Questions
Have a few questions about swapping a K into the teg.
1. Will Kpro pass an OBD2 plug in test? I've heard that when Kpro is used, you can tell it to pass an OBD2 scan. True or False?
2. If I use the factory harness that comes with the engine plus the hasport plug and play sub harness, will that plug up to the matching K-series ECU?
3. If I use the matching stock ECU, will it pass an OBD2 scan?
4. Is it more expense to tune using Kpro then it is Hondata S200?
2.yes but ur going to need the conversion harness to plug into the ecu
3. you going to need a 02-04 ecu with kpro or a ctr ecu
4.and you can only use kpro you cant use s200 with a kswap
pm me with any other questions you might have i have a teg with a kswap....lol
haha yes I know. I have s200 w/ my ls/vtec now.
My question was, does a tuner charge more to tune a k motor using Kpro then a B-series using S200/chrome/etc
Reason I ask is because a friend of mine said tuners are charging more money to tune k swaps because they are more advanced. Only way to really answer it is to call one, but it's thanksgiving and I'm at work all day and really debating going K, and I guess it's time to really start answering my little questions I have.
697312lg
Mar 26, 2013 01:25 PM
jaydm ferio
Dec 12, 2006 04:04 PM
