DC2 - Civic Suspension Question
Old Sep 22, 2002 | 10:38 AM
Drew M's Avatar
New User
Default DC2 - Civic Suspension Question
I have a GSR that was wrecked and I plan on swapping it into an EG hatch. I know I need to replace the rear LCAs in order to use the GSR shocks/swaybar but do I need to replace the UCAs and the trailing arms as well in order to use the GSR rear brakes?
TIA!
Old Sep 22, 2002 | 05:23 PM
poison's Avatar
Default Re: DC2 - Civic Suspension Question (Drew M)
ya, you will need those in order to do rear discs. I don't believe the rear discs will work with the stock civic ones, but GS-R's you should have no problem with the install
Old Sep 22, 2002 | 05:58 PM
fowler!'s Avatar
It's easier and quicker if you use the entire assembly. No point in taking things apart when they are virtually the same thing..
Old Sep 22, 2002 | 06:27 PM
Drew M's Avatar
New User
Default Re: DC2 - Civic Suspension Question (fowler)
I have to take it apart though. Here is why - I had a GSR. It hit a tree and bent All 4 of my control arms and both of my trailing arms but the brakes/hubs are fine. I don't want to buy an entire brake swap because I don't need it. I was just curious if I needed to replace the trailing arms in order to run the GSR brakes I already have. I know I need to change the LCAs to run the GSR shocks etc.
Are the UCAs the same between a DC2 and an EG?
BatLude
Sep 25, 2005 10:27 AM
edo3276
Jun 17, 2004 05:56 PM
Jdm93civic
Nov 25, 2003 05:16 AM
SoloSol
Mar 4, 2002 02:51 PM
