tps sensor on after high rev
Old Nov 25, 2010 | 07:11 AM
250r king's Avatar
Default tps sensor on after high rev
I just put on my new throttle body on my gsr obd1. I set my fuel/air screw to 1 1/2 turns out from lightly seated . Then my tps sensor was turned all the way to one side made idle a lil lower . car didnt run any better performance wise then moved tps over to center had better power . but now code seven being throwin when I get on it when hitting 3rd gear . Is the sensor going out or it just not set right . I figured it out the screws weren't tightened down enough fix the problem . I know the air/fuel adjustment setting verys for each motor but what is a good starting point for it
Last edited by 250r king; Nov 25, 2010 at 08:26 AM. Reason: figured out what was wrong
BakktoJDM
Honda Civic (2001 - 2005)
Apr 24, 2009 06:26 PM
deucedeuceEK
Apr 27, 2007 02:39 PM
hondaokie
Jan 14, 2005 01:28 PM
boosted hybrid
Apr 1, 2002 06:20 AM
