WHAT HP IS AN AREOMOTIVE A1000 CAPABLE OF
Old Nov 24, 2010 | 06:11 PM
adam1027's Avatar
Default WHAT HP IS AN AREOMOTIVE A1000 CAPABLE OF
I have a B18C1 sleeved,84mm pistons,mild head work with skunk2 cams,GT4294R precision turbo on 1600cc injectors
Old Nov 24, 2010 | 06:18 PM
sanman000719's Avatar
Default Re: WHAT HP IS AN AREOMOTIVE A1000 CAPABLE OF
i was told around 800 on gas
Old Nov 24, 2010 | 06:55 PM
tony1's Avatar
Yeah, mine was showing major problems around 860whp. Anything over 800 I'd go bigger.
Old Nov 24, 2010 | 07:09 PM
Garage 808 Hatch's Avatar
Mine said fuuuuuuu at 850. Pressure dove bad, and couldn't produce more than 13:1 AFRs.
Old Nov 24, 2010 | 08:11 PM
2k.civic.si's Avatar
its good to max about 1000 crank hp or about 830whp with not much headroom on a turbo car. good up to about 1300hp on a n/a car (not going to happen on a honda).
Old Nov 24, 2010 | 10:31 PM
cpl racing's Avatar
Question, what pumps are available if you want more power than this?
Surely that power figure varies depending on which dyno you measure the power on and if so which one would be correct based on the fuel flow available from the pump?
Old Nov 24, 2010 | 10:39 PM
.adam.'s Avatar
dual bosch.
Old Nov 24, 2010 | 10:57 PM
jdm inc's Avatar
dual bosch 044 are good to 950+ with Id2000 injectors.
Old Nov 25, 2010 | 02:36 AM
xtremvw's Avatar
dual aeromotive a1000 is what we have no problem but only making over 800whp
Old Nov 25, 2010 | 04:33 AM
Innes's Avatar
weldon 2015, 2025, etc
Old Nov 25, 2010 | 05:31 AM
evilone's Avatar
Had a1000 ran out at 940hp with Fic 1650's on a dynapak not sure what that would make on a dynojet
Old Nov 25, 2010 | 05:41 AM
jdm knight's Avatar
On my set up I only made about 650hp with the a1000 and 1600cc injertors, and it was runninig out fuel at that hp level!. It was a brand new pump , I had to switch to a eliminator pump and made about 790hp and still plenty of fuel left.
Old Nov 25, 2010 | 08:04 AM
Mr. Em1's Avatar
Yeah as others have said it is about 800hp they start to run out of firepower. The dual Bosch 044's are very popular choices and as someone else has stated the Weldon pumps worked very well as well. I have heard a lot of negative things about Aeromotive products, but on the flip side i have seen so many people running their products that I don't see how they could be so bad. Personally I have their Fuel filter and Fuel Pressure Regulator and both have worked flawless for me. I think that for the price you are getting a pretty decent quality part. As they say " If it ain't broke, Don't fix it!"
Old Nov 25, 2010 | 08:38 AM
Ls_dx's Avatar
Also depends on what fuel you are running and at what pressure..
E85, race gas etc.
Old Nov 25, 2010 | 10:32 AM
hello1320's Avatar
Can someone clarify the difference between running pumps in series vs parallel
Old Nov 25, 2010 | 10:43 AM
weldon for 800+ with some 2200's is the way it goes
Old Nov 25, 2010 | 11:21 AM
i think the a1000 is an awsome deal for the price you can get them for, and the amount of power you can actually put down with the unit
Old Nov 25, 2010 | 11:26 AM
Poootie's Avatar
if you already have a A1000 and wanna step up. Might as well get the Aeromotive Eliminator . It should be a straight swap out. So you don't have to re plumb your system.
And i know of a few cars making wellll over 900whp on it.
http://aeromotiveinc.com/products-pa...tor-fuel-pump/
"• 25% more flow at pressure than our A1000 Fuel Pump."
Edit: looks like it's a -12an in and -10an out.. (so if you were already running a A1000 , you'd have to swap the line/Fitting from the sump to the pump from a -10 to a -12..)
Old Nov 25, 2010 | 12:30 PM
nos3tc's Avatar
http://www.magnafuel.com/products/ki...mps%20kits.htm
Old Nov 25, 2010 | 12:38 PM
nonvtecallmotor's Avatar
Weldon is the way to go. Plus the LIFETIME warrenty is nice too
Old Nov 25, 2010 | 01:05 PM
CO_RaceFab's Avatar
Which weldon pump the big ones im seeing can only operate at 80psi
Old Nov 25, 2010 | 02:12 PM
adam1027's Avatar
E85, race gas etc.
I run Q16 not sure if that make a difference
Old Nov 25, 2010 | 03:09 PM
tony1's Avatar
For 1000+hp get the Weldon 2345. Gotta remember when looking at pumps at that level, we run a lot of boost so the fuel pressure will be high, where flow is the lowest.
Most of the Weldon pumps will do more pressure than they're rated at for short duration.
Old Nov 25, 2010 | 04:25 PM
CO_RaceFab's Avatar
Ah thank you
Old Nov 25, 2010 | 05:27 PM
xenocron's Avatar
Running pumps in Series will allow you to make more PRESSURE but less flow, while running pumps in parallel will allow you to flow more fuel but you wont be able to run as high a pressure.
For instance Dual Bosch 044s in parallel will start to drop off in pressure at around 120+ psi...but if you put them in series you'll be able to make 160psi with them...however your flow (amount of HP you can make) on them will not be nearly as much.
