Piston rings? Or valve seals? Pics, and taken apart, YOUR INPUT?
Im currently looking for pics but basically my problem was when i turned my car on, white smoke exerted my exhaust.. As the car warmed up more and more smoke came out at idle, when i revved it, huge puffs came out.. I did compression test was 110 bleeding 120 bleeding 120 bleeding, 110.. All pistons had a bit build up on them, valve seals looked fine no build up or anything abnormal, they were sticking out, not pushed in= ++
Piston rings were shot, replaced them. OIL RINGS on piston were FROZEN, didnt move at all, replaced them too
Cylinder 1 wall was warped, got all cylinder walls honed
replaced head gasket, resurfaced the head, changed rod bearings, piston/oil rings, honed cylinder walls, cleaned up build up, and a few other things.
WHATS YOUR INPUT?
THANKS!!
WHATS YOUR INPUT?
THANKS!!
natz20
Mar 15, 2008 09:55 PM
v8killaz
Feb 20, 2008 12:20 PM
